Windshild wiper arm removal tool
Ronson25
So i have to replace the wiper arm on my vehical and never done one on a car before do i need the tool or will it pop right off like on equipment ive done... The tool looks cheap so i didnt want to buy it unless i need it.
Dave455
Sussex, England
Normally you just flip a plastic cover off, undo one nut, and you should be able to remove the wiper.
Depending on the vehicle, and how long the wiper has been on there, it may or may not come off easily. I find maybe about 50% pull off, 25% need a tap or pry, and 25% won’t shift without a puller.
I got the puller shown for the equivalent of less than $30 and it’s quite good quality, even though made in Taiwan. I haven’t found a wiper it hasn’t shifted,57BD271D-6806-47C0-87E9-6136F9937432.jpeg
JradM
Alberta
I've removed wiper arms. I've never needed one. For a long time, I was oblivious that a specialized tool existed. I would try first and buy the tool if you struggle. I have needed to wiggle wiper arms a bit before they popped off.
I became aware of this special tool the day I saw one marked as clearance at Princess Auto. It was ~$2 and I actually bought it thinking it might make a handy small puller. I haven't used it on a wiper arm yet.
Wrench97
Southeastern Pa
Second gen Ford Escapes can be tricky, I had my junior tech break the wiper motor cast aluminum frame while pulling on the arm trying to remove so watch the pulling and prying if you don't know what is holding it together.
R
Ronson25
Well i got the old one off with a bit of tapping new one will be here tommorow.... I might just buy the puller since it does battery cables to
blarf
depends on the vehicle
Yep. I've had mixed luck on my cars pulling and tapping a bit. Nothing else will fit so I dropped the coin ($140 or so) on the BMW tool. It's got spring loaded adjustable jaws. When you need it, you'll know.
Buster21
Idaho
Looks like the one I use is the same as the auto body tool mart one shown above. It's worked on everything I've tried it on.
Mgdoug3
KY
I had a KD one and would buy another one in a heart beat. I use it for battery cables though and makes it an even easier job.
setfocus
rust belt
I've got a snapon battery clamp puller that works pretty well for wiper arms. In fact I actually bought it for wiper arms. It's only been used on a battery a few times
I've also got an old little craftsman 2 jaw bearing puller that sometimes fits
