Been waiting for those pics Kay..lol looks awesome!
Ditto!
Harry would wave his wand adn magic thr inside if that cubord into a castle...
Pre Smog; I replaced the spark plugs and wires in the 95 bird. I think all were factory - only a bit over 50K on them, but they are 26 years old, adn its been getting terrible mileage.
vanturbo
Orlando FL
Tested the new 4’ LED lights before installing- these have a 3-position switch that lets you change the color of light: 3000, 4000 or 5000. They work great, and the differences in colors are quite noticeable. I might have to order some more of these!
Ronson25
Managed to change water pump on my daily driver despite both legs being in cast and really shouldnt have done it but i was bored and it needed done. Thankfully i had my dad to be gopher so i didnt have to run around
Kevkx125
DOUGLASSVILLE, PA
Tried the blue magic lens restorer worked ok , not like new but better I think,
kaymccampbell
Upstate New York
Cut the first stair tread to finish size. Routed the bottom to clear the welds. Cut the anchor slot in the back edge. Tried to ease the front edge. Exploded the router bit.
After I got a new bit, tried to sand the tread. The hook pad on the sander STB. Ground it off. Glued a new one on. No sander till tomorrow. Took in a few Crapazon packages. Put the contents away. Labeled a new bin for ANC supplies. Drilled some holes in the stairs. Tried to drill the tread using a vix bit. It crumbled. Marked the tread and drilled it off the stairs. Took the Dingo out. Brought it back. Moved the metal lathe and shear, brake, roll. Put the new trash can in it's new home. Gained almost 2' of walking clearance around the bench grinder.
LeonardY
Southern California
I decided to hang all the clamps on a section of wall. I finally got into the garage and built some test brackets. Made some modifications to my design.
Bulky waste PU prep for next Friday, I had to do the worst of the heavy lifting before my last eye surgery on Tuesday, as I'm allowed NO heavy lifting or even bending over to pick up a tissue for a couple of weeks after... I can squat as long s the head is elevated. Also removed the kitchen AC for the winter; packed it in its box and back in the shed loft. I'm SO glad a I setup a hoist for heavy/bulky loads for the loft...
CoogarXR
Cleared the floor from my last load of projects/work, swept, took a deep breath, then unloaded the next van-load of projects/work onto the nice clean floor, lol.
raffaelli
I finished moving everything to storage for about 6 weeks while the slab is removed and replaced, then quartz floor. Now that it is empty, I am standing in there trying to figure out if there is a better way to organize.
PelicanPines
Looked for places to put my tools from the pawn shop yesterday…. They are still in the box cause I’m out of room everywhere 😂😂😂. I really gotta organize the basement then add another toolbox to the fleet.
A solution I have been using... is simply create a new Tool storage location. The new location would have to be in a different room/building.
1. Garage (main tool depot)
2. Big shed
3. 3D Printer Room (way too many tools in there right now)
4. Spare room (All my Klein Tools)
5. Kitchen drawer
6. Master bedroom suite (go bag... )
7. Trunk of car I barely use
niget2002
Josephine, TX
Part in the garage, part in the house...
Started designing a new enclosure for a CNC machine that will be living in my shop for a while.
I'm going to try to weld up a frame to keep the machine as close to the ground as possible. Current tentative enclosure size is 66x46x42".
This should still keep the top low enough that I can mount my laser and 3d printer to the top of it. Then all my robots will be in one tidy place instead of strung out over the whole shop.
I need to go get some 1" angle and start fabricating.
LS6 Tommy
Northern NJ
I can unequivically say Pine's garage is at the same time amazing and overwhelming.
I don't mean that in a bad way, either.
Tommy
PelicanPines
Tommy
It's gotten MORE labelled and organized as projects have been completed and new tools were installed.
I'm currently in a mode of "disposing" of projects I will never get to... making more room for me and my followers.
LS6 Tommy
Northern NJ
Guys, most of his "followers" are the local deer, black snakes, raptors and other cool critters I don't have enough of here in Denville...
Tommy
nateo
Embrun, ON
Slapped up a 24" magnetic tool bar by my lathe. Right now it's just mounted to the underside of a desktop that's leaning against the wall waiting to be installed on the lathe stand when I refurb it (someday...).
Good thing I grabbed two tool bars the other day, this one is full already!
FMB4
Rolled our lrg main waste management trash bin into our garage. I figure that having it in our G might push me towards filling it with some of the worthless junk that I've been collecting and hoarding for the last 8 yrs.
welder4956
Birmingham, AL USA
Got out the epoxy wood filler and ladder to repair the latest round of woodpecker holes on the chimney trim boards. Not sure why they are so partial to that area. Thinking about replacing with pvc trim or cover with aluminum trim. Dang woodpeckers!!!
kaymccampbell
Upstate New York
You've got bugs in that trim. Get rid of the bugs and the birds leave.
