Sounds reasonable. Just either use lighting rated for use in totally enclosed fixtures (a small subset of LED bulbs), or open some ventilation holes in the shelf around the base....Looking for ideas on lighting for the globes, I did find some porcelain light bases I can attach to the shelf. Thinking of using them
Thanks rlitman! I did find a 6 inch flex socket extension that will get the bulb to the center of the globe and will use with a 25 watt appliance LED. I turned it on and left it for about 3 hours, the globe lens was cool to the touch, no warmth at all. When I get going on the shelf I will post pictures of what I end up using. Thanks for the tip on ventilationSounds reasonable. Just either use lighting rated for use in totally enclosed fixtures (a small subset of LED bulbs), or open some ventilation holes in the shelf around the base.
Also, an A19 bulb will likely sit a little low in those gloves to get the element centered, so you may want to raise it up from the porcelain with a socket extension.
I'm sure the globe won't get hot. It's just the LED bulb. They're notorious for having cooling issues when air cannot flow over them. Though appliance bulbs should be meant to handle that abuse, and the 25W equivalent LED bulbs are using something like 3W, so the total heat output should be negligible. Also your globes are pretty big. Heat issues appear when you put a 60W and higher equivalent bulb into a jelly jar and stuff like that.Thanks rlitman! I did find a 6 inch flex socket extension that will get the bulb to the center of the globe and will use with a 25 watt appliance LED. I turned it on and left it for about 3 hours, the globe lens was cool to the touch, no warmth at all. When I get going on the shelf I will post pictures of what I end up using. Thanks for the tip on ventilation
Well done!Here is a picture with the lights on, just hard to read them in the picture but they sure look good in person
Thanks Mike. For many years I always had side jobs going and met people thru doing work. I always have had signs and stuff around and every so often someone would bring a friend to look. Many years ago a guy stops by one Saturday morning and says I don't know if you remember me but I came with my friend to pick a small project you had done for him. I remembered his friend but not him. He says to me, I have a few things that were my dad's I would like to give you. I said thanks but why did you want me to have them. He goes on to tell me a couple of stories about his dad and then says. I want you to have them because you shared what you have with me, somebody you did not know. These things from my dad were items that he saved but never shared with me why he saved them, but when I looked at your cans and whatnot, I realized that my dad would have really enjoyed looking at your stuff. These few cans I brought are doing nothing at my place but catching dust. I want you to have them because I know you share with others the things you have collected and other people will see these few cans that my dad saved. There were 8 nice small collectable cans in the box.That is awesome. I am always impressed by those of you who open up your shop to others. Just the thought of that makes my head hurt and stomach churn. I wish I could get past that but just can't bring myself to do so.
Mike I definitely get where you are coming from, there have been times when asked, my gut feeling kicked in and I have come up with an excuse for not being availableThanks for the story Jeff. I can appreciate that but it is still hard to wrap my head around.
A guy came by Friday night to drop off a welding project to me and brought his friend with him because he had watched a few of my YouTube videos and wanted to see my shop. While I was flattered at the time I was also anxious because I did not know this young man. I guess that is just something I need to get past.
