Best small adjustable wrench
Dakotadadv8
Like others have mentioned adjustable wrenches should be secondary to a set of good wrenches, metric and sae. CM USA and Crescent USA are good when I seldom use them for my DIYer projects. Snap-on ones do look solid.
Bubba Fett
Eastern NC
The Channellock adjustable is probably the best on the market right now. Klein also sells good ones. Both of these, and most other high end brands these days, are made in Spain by Irega.
Crescent wrenches are OK, but not great. The US-made versions used to be pretty good, but the last years of production were sloppy. The old Western Forge Craftsman wrenches were quite good, but the old J.H. Williams wrenches were the best, IMO. You may be able to find some of those on the 'bay, or at yard sales, etc.
48548
Phoenix
My favorite are the top, which are the Japanese with on odd spring in the adjuster and 2 colors for 2 different thumb screws that make is really tight. Channellock lock from Spain are my favorite and Irega and the bahco, love the screw on the end....
48548
Phoenix
A few more I found... I do love my snapons.... but Spain is where it is at these days.... my grand fathers proto....
RAS61
Low Country, SC
What have you been using for situations that require a lot of torque but do not allow you to use a box end wrench, or a socket? Is this Saker wrench any good?
I do have Snap on flare nut wrenches, but they can be too fat to use sometimes.
Why not just use an open end wrench? Adjustables are useful, but terrible for high torque situations, and I haven't seen an adjustable yet where the head is smaller than an open end
ThePostman
Virginia
They've dropped the price on this. $63 now. It cost me $80, from the website. For 7th generation civics, this tool is invaluable for inner tie rod replacement. It's very useful.
And for those that said an adjustable had no place, or doesn't stand up, try this thing with a quality ratchet or breaker bar. I don't need a whole set of jumbo crows feet either for what I do.
Bubba Fett
Eastern NC
Adjustable wrenches have their place. I imagine electricians and HVAC technicians use them quite often. Those guys, along with plumbers have to go TO the work site. The work doesn't come to them like it does for most mechanics, so they have to lighten the load, and an adjustable wrench accomplishes that. Plus they are great for fittings, or holding nuts in place with screwing down a bolt.
Plus some adjustable wrenches can also be impact wrenches. ;D
M635_Guy
NC
There is a reason everybody says the Knipex pliers wrench is a must have: IT IS A MUST HAVE! Pay up and be happy. Once you use one you'll never go back. The guy that invented this should have his face put on Mt. Rushmore.
I agree with this. My adjustables just lay in the drawer for a while after I got my Knipex set, and eventually I moved them to the "family" cabinet (tools that can be used or loaned without asking).
Project Farm did a video on adjustables recently, and vintage Craftsman kinda *****-slapped everyone else. He liked Crescent and Klein for stuff in current production. He didn't test some brands preferred here (Proto, SK, etc.), but did have Bahco, Hazet, Gedore, and others.
Htscheg
Buffalo, NY
I have the Knipex tool (rebranded Matco version), I absolutely love the tool, works great and I highly recommend it
mbunimog
Frederick, Maryland
The above 6 inch Bahco was given to me 65 years ago when I started as a mechanic at a fix it all shop in Denmark. including blacksmithing. farm machinery repairs, over the road truck repairs, motorcycles etc. It has followed me all these years around in the various places we lived in the USA and other parts of the world and has a great deal of sentimental value to me. I still used today in retirement at our farm next to the Appalachian trail in Maryland
Ton ton
Page County,VA
Looks like it works in metric and standard!
m151
project farm just did a must see test on adjustable wrenches. Hint: the lightest AND strongest "was" made in the USA.
joshmodelskidoo
mid western michigan
All modern adjustable wrenchs I have looked at have sloppy jaws and adjusters. The Milwaukee seems to be the best but it’s borderline to me. My favorite is a made it best hardware brand from about 2001
IndyGarage
Indy
I use adjustables quite often. On stuff that isn't real tight and you don't know what size the fastener is, they can save time.
I have a few that I like better than others. First is the Stanley locking adjustable wrench. It's sort of a combination vise grip and adjustable wrench. I have a couple of them and use them quite frequently. They are like a small vise that you can hold one Item in and then twist something else off - like when you have to separate an air line fitting from a hose.
The second adjustable I like really well is a Stanley Fatmax adjustable that I got several years ago. I have a 10 inch and a six inch and they are both very nice and tight. They have a black oxide finish and a rubber handle.
My next favorite is one that I think is a diamond brand - made in the USA - probably from the 60s or 70s. Very nicely made.
I have the Knipex Pliers wrench in a couple sizes - I just never found them all that useful - Yes they are quick, but you can't hold them tight enough to move anything but pretty loose fasteners.
dscheidt
If you have them oriented properly, the force of turning the fastener serves to push the jaws shut, and you can pull only on the longer movable handle.
I don't often use mine as a replacement for an adjustable, because they often don't fit where I need to get at. If I worked on gas fittings and stuff more, I'd use them a whole lot, because they're so much faster to set than an adjustable.
IndyGarage
Indy
Perhaps I've done it wrong. I've used the pliers wrench a lot, just never found them to be as magical as some here say they are.
I will say they are fantastic for bending and straightening flat metal, which is what I end up doing with them most of the time.
fastev
Portland, OR
The one in the original post I've always known as a union wrench. Never tried one on something other than a threaded union. My old Ford wrenches are the best adjustables I've ever used, and I have one in a 6" size. Love that thing.
VolvoRyan
Kentuckiana, USA
Old Snap-On adjustables were pretty good. I believe they were made by Diamond. I have a small one. Rarely use it but it works well when I do.
I have a full set of vintage (1970's) Blue-Tooths from Kenosha, WI. The things are still less "jiggly" than a lot of brand new wrenches. Not sure how that can be.
-Ryan
64merc
Texas
Like you, I've mostly used mine for bending metal brackets and such. I always thought they were overrated, but I started to appreciate them when I used them on plumbing and gas fittings. I don't think they are very handy for automotive uses IMO.
