Best small adjustable wrench
camaross
Maryland
I do not have good luck with adjustable wrenches. They seem to slip too easily. I love this Ridgid hex wrench a lot. It has been a life saver so far. I like it so much that I want to buy a miniature version of it. Unfortunately, Ridgid does not offer such a tool.
What have you been using for situations that require a lot of torque but do not allow you to use a box end wrench, or a socket? Is this Saker wrench any good?
I do have Snap on flare nut wrenches, but they can be too fat to use sometimes.
C
camaross
Maryland
Something like that might be what you want. The jaws move in parallel so they grip a hex real well.
Thanks for the recommendation. That seems to be a very interesting tool. The only con is that it requires a squeezing force in order to use it. The Saker tool I mentioned above, in comparison, is self tightening.
gewf631
Chicago, NW Burbs
I really like this from Irwin/Vice Grip - it's similar to the "channel-lock" that Random Guy posted, but the jaws are smooth, so it doesn't mar the surface. I picked-up mine at Menards, but it's available from Amazon for about $20
Mandres
Get the knipex pliers wrench, you won't regret it. The 7" size is perfect for small stuff but still opens more than an inch. The price put me off for too long, I wish I had it years ago it's totally worth it. Adjustable monkey wrenches are obsolete now.
jeepxj
thool
Rochester, NY
To be honest, I find them moderately useful to throw in a bag if I'm bringing a subset of my tools to help a friend out. Rather than bring every wrench to an unexpected set of fasteners, an adjustable wrench can save the day. At home, I rarely use it though.
Are there brands that don't have a ton of slop? I have a HF set that has very loose movable jaws that I straight up hate.
Wakefield
Arlington VA (but would like to get out to country
I still find uses for the "adjustable nut rounder" but only for low torque non mission critical work.
Paco
Helps to "wiggle" the wrench while you try to tighten the knurl some more before putting force on the nut.
and was the rule to "always pull the fixed jaw side"? Think some had an arrow on it suggesting which way to place it. So that the force tends to push the adjustable jaw down and not pull it up allowing some of the spreading force to be dissipated by friction with the wrench body and not by the knurl threads alone?
Wakefield
Think Craftsman by Western Forge varied,some were tighter than others,I have a 15" one that is O.K. The 15" and up were noticeably stouter and more robust for their size than the smaller ones
unfortunately heard that Western Forge went out of business,was heavily dependent on its sales to Sears as Craftsman? Did Western Forge make adjustables for Wright?
dscheidt
That pliers is a poor copy of the pliers wrench that random guy posted. Everything that does, the knipex does, better. The only thing the Irwin has going for it is that it's cheaper, but the Knipex are worth the extra money.
RoundedNut
driveway
I like TOP and Lobster brands from Japan for adjustable wrenches.
They still have a place in my tool bag/box as complementary tools for my Knipex Cobras and Pliers Wrench. Good for holding one end of a line or a nut while you turn with the Knipex pliers or a powered driver.
pizza
Midwest, USA
imo you need knipex pliers wrench AND quality adjustable wrench.
like @RoundedNut said, look at TOP and Lobtex. some thoughts on those adjustables:
why both and not just knipex PW?
PW is a great tool for more than just turning hex fasteners. they're super high leverage. they're great for bending stuff. and for fasteners, you get so much contact pressure that it will basically never slip and round over.
unfortunately, it occupies your entire hand. you can't hold it with your foot or elbow or whatever. also, if you let go, it falls on the ground. very annoying in tight spaces or when you're running out of hands. this is why you need adjustable wrenches too.
steaks&anvils
Colorado
that saker wrench looks like a reboot of an old style adjustable. There are tons of old adjustable's that work "like" that.
Take a look at these:
and some light reading:
Dzmax77
Milwaukee
YIGII
It looks great
C
camaross
Maryland
I decide to buy the Knipex raptor wrench.
Many thanks. I decide to buy the Knipex Raptor wrench.
Having more than two contact sides and having teeth really help.
Dzmax77
Milwaukee
I spent a lot of money on Proto adjustable wrenches that lay unused and lonely in their drawer.
Some ladies have shoes they’ve only worn once in their closet. At least your Proto’s won’t go out of style and can be used for decades to come. And arguably, they may even increase in value - as we’ve seen many NOS Craftsman USA tools have.
JradM
Alberta
If you want a traditional adjustable wrench, the best version is the Channellock-branded Irega. You might be able to spend a lot more for something similar, but you certainly won't find anything comparable in the same ballpark (i.e. I bet you could budget 3x as much and not get a better adjustable).
However, the Knipex pliers wrench is a game-changer. Don't dismiss it just because of the price. It's useful for way more things than a regular adjustable wrench - albeit the utility is hard to explain until you use one. It's not the same as smooth-jaw pliers from Irwin or Channellock.
The clamping force means you can grab onto mangled fasteners, squish/squeeze things together, use them to hold things while you work (say at a bench grinder)... You can "ratchet" them for repetitive turning. Precisely bend things back into shape (ever mangled a key? Put it in your pliers wrench and squeeze).
You mentioned:
Keep in mind most of the squeezing force happens when you pull on the wrench to turn the fastener. It's not like a pair of pliers where you have to be squeezing hard to ensure nothing slips. The pliers wrench multiples your squeezing force so you really don't have to squeeze that hard.
If there's space, I'd often sooner use the pliers wrench over the open end of a combination wrench - you certainly can't say that about an adjustable wrench. Think about that - if the reason you wanted an adjustable was because you weren't sure what size combination wrench to grab, didn't want to carry a handful or the length of a combination wrench isn't needed, the pliers wrench not only serves the same function but actually offers advantages over the "proper" tool.
If it's just too expensive, consider the WIha version. Taiwan-made I think, versus the German Knipex, but it is also a good tool and should be available cheaper. Irwin makes one too, but I don't think it is as good. There's also a weird Lenox version intended for plumbing.
You might be able to tell, like any recent religious convert, I'm eager to evangelize the pliers wrench. I'll keep going if I have to.
pizza
Midwest, USA
agreed, PWs are the ****.
however...
imho, you can in fact get a superior adjustable wrench for less than double:
Channellock 6WCB: $27.45 shipped
vs
TOP HM-32: $43.64 shipped (that price gets a bit better if you add more stuff to your azjp order)
JradM
Alberta
What's better about it? Not disputing, I just don't know anything about that adjustable.
Channellock opens wider and has little slop, adjusts smoothly and has a nice comfort grip. I'm willing to accept I was wrong and you can do better at merely twice the price, but I need details! 😄
P.s. I may have been engaging in a little hyperbole, but I do think Channellock makes a damn fine adjustable for a very reasonable price. Before spending more I would much rather get a pliers wrench.
m151
On advise of this site I bought the Top "zero monkey", It's great for the car glove box and great quality with no backlash. There are endless replacements for the traditional adjustable wrench which is only because few make a quality wrench. When done right the basic design is good.
Hotrod33809
TN
HJE has some great prices on Crescent adjustables, never had any issues with mine but like others I don't use it a whole lot.
Crabman
Alexandria, VA/Dameron, MD
If OP is really looking for small adjustable wrench, I have a 4" Proto which is great.
It does come out once in a while and is handy when it does. Lardy, Sorry to hear about your lonely set.
As suggested there are good old USA ones on ebay as well that would work.
67King
Friendsville, TN (Knoxville area)
Actually, it doesn't. They are also self tightening when oriented properly (if oriented in reverse, they do require a squeeze, though).
Attached to the House
When I think of small adjustable wrenches this 4” USA made Crescent tool is what pops in my mind. Those are 10mm sockets lined up on top to put size into perspective it’s smaller than 7 sockets lined up. They are $15 and available at Harry Epstein linked below.
48548
Phoenix
Channel lock.... bahco.... here are mine....
dnschmidt
Phoenix, AZ
There is a reason everybody says the Knipex pliers wrench is a must have: IT IS A MUST HAVE! Pay up and be happy. Once you use one you'll never go back. The guy that invented this should have his face put on Mt. Rushmore.
