American Scale #79 rebuild
royce
fairbanks ak
This project started with a conversation with Kevin Scott about fixing the swivel jaw pin and It snowballed from there.
I need to disclose that in no way, shape or form am I machinist and this would not have happened without a ton of help from Kevin
Started with cleaning up the swivel base surfaces
R
royce
fairbanks ak
Then cleaned up the swivel jaw surfaces and bored the swivel jaw pin bore
R
royce
fairbanks ak
Then moved the center bolt bore and the swivel base locking bolt bores
R
royce
fairbanks ak
Then cut a 1”npt thread in the base and made an insert to get to 3/4 thread
R
royce
fairbanks ak
Then new swivel base lockdown bolts and nuts
Shiftless
East Bay SFO
That’s gonna be better than new!
I‘m glad to see that Kevin’s Bridgeport is obviously now up and running.
Excellent work!
R
royce
fairbanks ak
Then a new shouldered center bolt sleeve
R
royce
fairbanks ak
Then turned, grooved and bored a new swivel jaw pin
Shiftless
East Bay SFO
Thanks Royce
I assumed all of the flattening work done on the large surfaces was done with a regular mill rather than the specialized boring mill.
R
royce
fairbanks ak
Then cleaned up the top and bottom of the slide
ChefRex
Nice, wish I had the equipment to make something like this to happen, following.
R
royce
fairbanks ak
Then let in some bronze round bars to take up the slack
R
royce
fairbanks ak
Then bored the slide for a bronze bushing and faced the spindle
R
royce
fairbanks ak
Next up a handle
Wanting something less cumbersome than the heavy sliding handle, I opted for a pivoting handle cut from navel brass.
The large soup can spindle boss lent itself well to milling flats on it, without sacrificing integrity.
Also added Belleville washers to give enough friction to keep the handle in any position.
R
royce
fairbanks ak
Then bored the swivel jaw lock pin and cut a new pin
R
royce
fairbanks ak
The faced the jaw mating surfaces and the jaw tops
R
royce
fairbanks ak
Thought I would give japanning a try for the finish.
Not perfect by any stretch, but not bad
R
royce
fairbanks ak
And finally assembly
This was such a fun project, learned a trainload and as always, working with Kevin’s help was a treat
Royce
Shiftless
East Bay SFO
As a major sidebar, would you please share your recipe and technique for preparing the Japanning mixture? You start with asphaltum, right?
R
royce
fairbanks ak
You bet
5 parts turpentine
3 parts asphaltum
2 parts linseed oil
Disolve asphaltum in turpentine, let stand overnight.
Remix and then add linseed oil.
Strain through paint filter
Apply with acid brush
Shiftless
East Bay SFO
Thanks Royce!
Did you get the asphaltum in artist paint tubes?
That‘s RAW linseed oil you use and not boiled?
Mix together at room temperature or warmed up a bit?
Thanks
R
royce
fairbanks ak
Thanks Royce!
Thanks
Thanks Royce!
Thanks
The asphaltum came in a tin from Renaissance art.
The oil was boiled but does not need to be.
Mixed at room temp.
Monza Harry
Windsor ON
Don’t let the looks fool you Larry!
The jig borer is new to me.
Thanks
That's NICE $#!+ any way you slice it Royce! You certainly did a Very Nice Job for Faking It (eye roll here, and as Al Borland says to Tim the Tool man Taylor, "I don't Think So Tim") Don't sell your considerable skills short Royce, patients, a keen observant eye, and creative/analytical thinking (as well as taking direction from some one with different skills [K Scott in this case] a truly RARE skill set today) are skills that transfer to many uses, and you [both] display all of the above frequently here! Thanks for Sharing! Harry
Shiftless
East Bay SFO
Mixed at room temp.
Thanks for all of the details. A neighbor is restoring some old woodworking tools and we have been talking about replicating the old Japanning finishes. I’ll keep you posted on our progress.
I have plenty of old vises (understatement) that might look great with that finish.
R
royce
fairbanks ak
Thanks Harry,
That is kind of you to say.
I’m really enjoying this new machinist apprenticeship and could not ask for a finer instructor and friend.
Royce
R
royce
fairbanks ak
You bet Shift,
I think everyone should try it at least once, to see the deepest, blackest, glass like finish.
I’d love to see what you guys come up with.
Royce
R
royce
fairbanks ak
Thanks
John, Lynn and all.
What good is a vise without a proper stand.
This one is unlike any I’ve seen or built.
3 legs cut from old beams
1/2”x 28” hex top plate
Maple bowling lane table top.
The top will be elevated over the slide, yet still allow around 75 degrees of swivel rotation.
Royce
Shiftless
East Bay SFO
That stand is gonna rock! 🍻
I love old bowling alley lane pieces. Did you grab enough of it to make a small workbench for your projects that don’t involve your usual welding of steel masterpieces.
R
royce
fairbanks ak
Thanks Shift,
Yes, I made a 6’ that I use for a drawing table,
a 12’, a 7’ dining table and a few end tables.
Not a lot of joy to mill, chocked full of hardened nails!
Jayman17
Seattle, Wa
That’s a great upgrade on your vise Royce, that handle is very unique. Great collaboration with Kevin Scott, thanks for posting this project. Great stand too. 👍
Jay
R
royce
fairbanks ak
Let in some 2-1/2” angle iron edge framing on the tabletop and started fitting it up.
