Snap On Torque Wrench Pivot Bolt Repair
Chipm
Georgia
I have an older Snap On CDI-made flex-head torque wrench with a broken pivot pin. The pin is available from Snap On, but I am not sure how to change it. It is pressed in? I'm assuming a hammer and punch would not be the way to go. I appreciate any advice!
C
Chipm
Georgia
I would just call snap on customer service and ask them
every time I call them they are helpful, and usually pretty quick
I tried that first, of course. This wrench was made by the previous manufacturer and is no longer supported by Snap On or CDI.
Ricky Joe
Roanoke, Va.
Too bad about no longer being supported. I had the same thing happen, and just had the dealer send it off since it needed recalibrated anyway after that. I had no real pressure on it, either. That was about ten years ago, give or take a year, and was about $60, if memory serves.
Walkers
Cave Creek Az
I would just use a pin punch, it is not likely to be incredibly difficult to change. Just make sure you have a good back up under it. A block of hardwood with a hole would work fine.
