86turbodsl
Got the narrow end closed up. I'm amazed how thin of metal can be joined using TIG. Tested fit on the Namco, it's a bit of a snug fit, but it does go in. I will try and tune it up a bit more before it goes in.
Got the sides sanded down so i can see what the beads look like. I think it'll pass leak test.
Hammered down the bottom to the side, and turned down the heat. Worked so good most of the joint didn't even need filler metal. Proper heat control is everything.
