Need info on this light
Hot shot
Virginia
Looks like 120 volt
Before I put it anywhere I want to put a piece of wire with plug on it to see if it works, light output etc.
any info on the bulb and wire size, plug I would need
Thanks
H
Hot shot
Virginia
Are the black and the clear coated one both hot or hot and neutral. Other words is it wired for 120. I’m assuming the thing D935C1D4-E7EC-41A1-8FD4-61BBA1B0D016.jpegon the top right of the fixture ( u can barely see in the pic) a dusk til dawn thing
nadogail
Coronado, CA
On the ballast, that transformer looking thing, there should be a lable identifying the connections and voltage requirements. Some ballasts have multiple taps for different voltages, the ideal would be a a Quadra Tap Ballast allowing 480,277,220 or 208 and 120 volts.
Norcal
You are not going to find a HID ballast for 220V made for US market, a quad tapped in particular, GE made their own ballasts, so the OP is going to have look for a label on the fixture for voltage information.
Bert_
NW Iowa
Judging by the connection diagram I would say 120v
It's a 400W probe start metal halide.
Bert_
NW Iowa
When the bulb burns out….. Toss it and install a LED fixture.
You will save money and thank me later.
Metal halide isn't bad. I would maintain it unless you're running it dusk to dawn every night. A halfway decent led fixture to replace it with be around $300. A cheap led fixture is probably less reliable
H
Hot shot
Virginia
Wired an extension cord to it
It worked for 5 minutes and quit
I guess the bulb blew
It still had a humming sound
Man that thing was bright
klassenl
Southern Alberta
Let it cool and try it again. When those are at the end of their life cycle they will gain full brightness and the go out.
A new bulb isn't that much money.
H
Hot shot
Virginia
Tried it this morning
Bulb came on and went off in 5 seconds
It did the same thing a couple more times
Is it the bulb or something else
mikedodge
Why put a plug to test it? Use a volt meter.
When my barn light stopped working I tried replacing the bulb and when that didn't work I replaced the whole fixture with an LED one. A good one costs $75-100 or so.
Bert_
NW Iowa
I wonder if it's actually a 400 watt fixture?
Looks like a nearly new bulb. Could be the wrong size.
cybrdyke
USA
If the bulb cant manage to stay on, it's either a bad bulb or a bad capacitor.
CD
alfredeneuman
Fullerton, CA
OP >>> When the bulb "quit" did it go completely black, or just dim.
When MH lamps start, they are bright for a few seconds, then dim and gradually brighten.
H
Hot shot
Virginia
Bert
It was daylight. Hadn’t had my coffee yet. Got to have that for the brain to function
Alfredeneuman. It was humming last night in the dark but not this morning in daylight
tried it again 20 minutes ago and it worked fine
I let it run for 15 minutes
My question now is could I take the photo sensor out of the equation and use a regular wall switch upstream I think the sensor had 2 wires going to it. Wire nut them together maybe
I’ll look at the sensor wiring in the morning
This is mounted on the top of the fixture
Is this the photo sensor. I’m assuming it is
I appreciate yal guys trying to help me out
Bert_
NW Iowa
Just buy a shorting cap. They are only a few dollars. Then you don't have to cut the wiring.
A couple wraps of tape around the sensor will accomplish the same thing when you don't have a shorting cap handy.
H
Hot shot
Virginia
I like the shorting cap
I’m thinking about putting the light on a let’s say a 2 1/4 galvanized pole which would be in the ground to get it in the air
What would be the best way to mount it on the pole. Haven’t bought anything yet
I’m wide open for suggestions
Here’s the bracket that came with it
Bert_
NW Iowa
How tall? That small of pipe will be pretty floppy if you go very tall.
