You are not going to find a HID ballast for 220V made for US market, a quad tapped in particular, GE made their own ballasts, so the OP is going to have look for a label on the fixture for voltage information.On the ballast, that transformer looking thing, there should be a lable identifying the connections and voltage requirements. Some ballasts have multiple taps for different voltages, the ideal would be a a Quadra Tap Ballast allowing 480,277,220 or 208 and 120 volts.
Quad tap ballasts are 120, 208, 240, and 277V capable.the ideal would be a a Quadra Tap Ballast allowing 480,277,220 or 208 and 120 volts.
No, they require a ballast.Looks like an edison-base bulb, shouldn't it have a voltage stamping on the brass?
It's a Mogul base. (Like a oversize Edison base)Looks like an edison-base bulb, shouldn't it have a voltage stamping on the brass?
That’s gonna be really bright. Don’t look directly at the bulb. I’d expect over 20,000 lumens.Thanks guys
When it gets dark I’ll see how much light it puts out
Metal halide isn't bad. I would maintain it unless you're running it dusk to dawn every night. A halfway decent led fixture to replace it with be around $300. A cheap led fixture is probably less reliableWhen the bulb burns out….. Toss it and install a LED fixture.
You will save money and thank me later.
You said it has a photocell. Do you have it covered?Tried it this morning
Bulb came on and went off in 5 seconds
It did the same thing a couple more times
Is it the bulb or something else
How would you use a voltmeter with no voltage to the fixture?Why put a plug to test it? Use a volt meter.
Something is wrong if the bulb strikes, then goes back out...There may not be anything wrong with the light.
I'd suggest plugging it in and letting it fully start. It may take 10 min or more.
Here's a simple way. It also serves as a surge protector.My question now is could I take the photo sensor out of the equation
How tall? That small of pipe will be pretty floppy if you go very tall.
