My 30X44 Detached
35k0
Minnesota
Make sure the inside is finished before you start to move in stuff
Yeah man, In a perfect world that would be the best way, got booted from our storage and had no other option so I’m working around stuff. *****, but could be worse.
Jackfre
N CA
I was just reading an article by John Siegenthaler on Air to water heat pumps for Radiant systems. I would suggest if you haven’t done the electric boiler yet that you check them out.
35k0
Minnesota
Thanks! I bought an electro industries ezb-eco system.
davecz
Indiana
looking great, I just built a 30x44 and wish I went with more roof pitch for room upstairs. That was a great add
35k0
Minnesota
Thanks! The added space is nice. I wasn’t sure about adding that cost either but made a last minute call.
jf1998
Awesome build. Job well done. May I ask if you could provide a cost breakdown. I am currently interested in these same dimensions and I am trying to get a ballpark price together. Thanks in advance
35k0
Minnesota
No problem
Building materials with tax were $14100
R18 18’x9’ garage door $2800 after tax
Concrete was buddy deal $9500
Pex was about $500 with foam clips
2” XPS r10 foam for under slab and 4’ frost protection wing all around was About $1400
Can’t remember what I paid for fiberglass insulation, ceiling liner metal and OSB for interior but I think around $4k
Boiler system was $2500
These prices do not include labor, shingles or siding.
jf1998
No problem
Awesome thank you very much. Also did your lumber price include trusses?
crepr12
You nailed your build time...Great garage/shop Enjoy...I'm stealing that idea for a ceiling once the price of "stuff" comes back down to earth...
35k0
Minnesota
Lots of guys around here do the ceiling this way, many do the walls and ceilings with the liner panels, they are thinner than siding and roofing panels and less expensive. I bought mine in 15' sections and overlapped the ends so i didn't have to make any cuts.
We stacked 5 at a time on saw horses, pulled layout on the trusses and pre-drilled to make installation easier, then raised each one up with a sheetrock lift and it worked amazingly well.
Menards sells them as "Dura-Panel"
