Is this stamped’I.H.’ In the circle or what?
The numbers on it are also puzzling...
Agreed!
I have a McKaig-Hatch DOE engineers' wrench that looks like it came from the same era. It also has a number ("1702") on the flip side shank that I've always assumed to be a model number.
Here's the top side.
I think the other number ("1046"), turned sideways on the shank near the head, is an AISI number for the carbon steel composition, which I have never seen on a wrench other than Herbrand, which is interesting and probably the sole reason I picked it up at the flea a few years ago.
But to get back to your wrench. If my "1702" is the model number, why does your wrench have two of them ("1551" and "6152")? No apparent correlation to anything or each other, and especially weirdly and seemingly unscrutable when it's a combo wrench with the same opening size, and that size is the same as one of my open ends.
It is! A strange one. And, as long as you went there, believe it or not, AISI 1551 is a strange medium carbon steel!
So half the wrench is medium carbon and the other half is a low-chro CV alloy? WTAF?
I have definitely not seen anything like that before.
Stillgottimefor1
Central texas
Reading about McKaig-Hatch in A.A. Suggested that they used alloy numbers on the tools, but different ones on the SAME tool doesn’t make sense to me either…🧐
MR.X
so the there's a 1559 MH 7/8 combo on AA which would lead me to believe that the 1551 on the OP's wrench is a tool #.
...and a 1555 5/8 combo on the "progress is fine..." blog.
Interesting. I criticize AA for getting plenty wrong, so credit to them for observing that. I'm a little surprised they didn't at least make a reference, with caveat, about the practice typically being exclusive to Herbrand and wartime, because it could maybe help date them. Heck, I would go out on a limb and say it maybe even raises the specter of the possibility that Herbrand is the OEM. They did make paneled wrenches.
^ That was in reply to Stillgottimefor1 (who needs a nickname).
7/16 1552
1/2 1553
9/16 1554
19/32
5/8 1555
11/16 1556
3/4 1557
13/16 1558
7/8 1559
which makes a little bit more sense, as long as 19/32" isn't part of the equation.
Stillgottimefor1
Central texas
