What kind of primer/paint for new garage?
ToddnMiss
California
I think this is an easy question, but I realize this question could be teetering on the "what kind of shoe is better, Nike or Reebok?" but, any help is appreciated.
Some Details:
* Garage is 600sf w/9' ceilings. 1 Wall is pretty much all garage doors.
* It is finished in drywall with a "hot mud?" final coat on joints; very smooth.
* I want the final paint to be something that can be easily wiped off like a kitchen wall (semi-gloss?).
* I live in California; climate is warm and reasonably dry.
* Money is not a concern within reason (say under $1k for primer/paint).
* I have plenty of stores nearby; Costco, HomeDepot, Lowes, etc.
* I have near zero paint knowledge.
My Questions:
* Should I primer first? If so, any particular type (prevents mold, or special for whatever type paint I should use in the next question?)
* What type of paint best fits the desire to be able to easily wipe off most splatters/spills (e.g. grease, etc.).
Responses/Opinions/Experience is appreciated.
Thank you,
Todd
Jack Olsen
Los Angeles
Are you talking about the inside or outside of the garage.
Aside from the particular brand, you're going to be fine with any decent primer and semi-gloss paint. I went with an exterior grade, since it's more durable.
T
ToddnMiss
California
The inside of an attached garage; two walls are common with the home, one wall is nearly all garage doors and the final wall is stucco on the exterior. Above the garage is a big game room.
Thanks,
Todd
T
ToddnMiss
California
I think some basic research has netted me this product:
Glidden 5 Gallon Interior Speed-Wall PVA Latex Primer/Sealer
Seems easy to clean, is extremely inexpensive at <$5 a gallon, and can accept different final paint products.
I may primer, sand, primer, sand then paint . . . still looking for paint suggestions though =)
Daniel Dudley
I am very fond of Benjamin Moore Aura paints, both indoor and outdoor. Excellent paint.
Top Rated
mpraddict
Central Ohio
I've used that primer. It's just a little thicker than water....WOULDN'T recommend it. Use a good primer and you'll have fewer top coats. If money is not a concern, I'd go with Sherwin Willams (for both primer and top coats). For top coat, you don't need the top of the line Duration, A100 would be fine. Agreed, Benjamin Moore is also a good brand.
Not sure why you'd need to sand between coats.
kartracer23
New Castle, IN
I'm in the process of painting my house. Bought 21 gallons of Duration @ 40% off on an Anniversary sale. :) It paints up really nice. Not too thick - not too thin.
Buy a good quality paint - not just for durability, but for ease of application.
ddawg16
S. California
It's the inside of the garage.....your over thinking it....
One good coat of Kilz primer....(rated one of the top ones by CU)
And use exterior gloss or semi-gloss as Jack suggested. The gloss reflects more light, does not let as much dust stick to it.....and the exterior paint is a bit more durable....which garages need.
I did all of my garage inside with Behr from HD....also rated very high by CU...
This is a rare pic of my garage right after painting was complete....why rare? Because the garage will NEVER be that empty again.
Will S.
The First State
I just went thru this same thing, and after a lot of research, I used Zinnser Bullseye123 primer; 20 gal of it. (4000 s.f. drywall). It is tintable (didn't matter to me), suitable for indoor/outdoor and contains a anti-fungal formulation (I'm on the water, so I liked that). H.D. & Lowes both sell it; may be a little pricey for some, but worth it to me, and I cannot find anything but good things about this primer, even on the paint talk forums.
My paint-of-choice, which I just finished the day before yesterday, was Duron Pro Kote, shell-white, egg-shell finish. Very good paint, and got a painter's discount at the store. (ask for it). The same paint is sold at S/W, called Pro Mar 400.
