Crowbarman55
- Joined
- May 22, 2021
- Messages
- 1,084
Garage is detached 24'Wx30'Lx8.5'H. Ceiling is covered with .5" OSB and walls are 2x4 construction and has fiberglass insulation in walls and ceiling. Walls are covered with pegboard. R12 insulated 16'x7' garage door and 2 fiberglass 36" insulated man doors on side and back wall. RaceDeck solid tiles on floor. Not the best but very well insulated no air leaks. I am located in mid lower peninsula Michigan so it gets cold in winter and humid summers. I work on a little bit of everything out there but not full time. Just want it comfortable to work in there.
I would like a Mini Split installed for heat and A/C. Wondering what I should get size wise and brand? What would you do if it was you? Garage is 220v ready also.
Thanks
Todd
Thanks
Todd
