joshmodelskidoo
Check this hf doyle vice out. Makes me think of a wilton. Im sure its not that nice but im pretty impressed
amen to that.I reinforce the notion that you can get an awfully nice used vise for a lot less money. I have two different styles of vintage USA Craftsman that are in VGC for less than $50.00 each.
Exactly what I thought too. I have one of the square back ones and the only difference i can find in those crappy screen shots is the forward part of the dynamic jaw looks a little different.Appears to be the same as the square back Craftsman 51888 vises.
how much does it weigh?Check this hf doyle vice out. Makes me think of a wilton. Im sure its not that nice but im pretty impressed
Same here! I have the Craftsman Pro 51888 also, and noticed the only difference in the photos to be the width of the base of the forward jaw. The Craftsman seems to be a little wider. May just be the photos though. Specs seem to be the same also. I own both Craftsman Pro square back and round back vises, and have been extremely happy with both! I don’t beat on them with a sledge hammer, but for everyday tasks in my home garage, they’ve performed great! If the Doyle is indeed the same vise, I would have no problem purchasing one if needing another vise. It’s nice to see that it’s also offered in a 6” model.Exactly what I thought too. I have one of the square back ones and the only difference i can find in those crappy screen shots is the forward part of the dynamic jaw looks a little different.
I’m a bit curious, do you mind measuring how fine the thread pitch of the screw is? No need to take the vise apart, just count the number of rotations to open the jaws an inch.For anyone interested... I stopped by the local HF yesterday after work because I'm in the market for a bench vise and wanted to look at the Doyle. I wanted to preferably buy something local I could put my hands on.
Well they happened to have one on display, only one on the shelf and yesterday morning HF put out a 10% coupon.
So I did what any self respecting GJ tool buyer would do, and put it in a basket before anyone else could.
Out the door for less than $127 with tax + the 10% off. More than I really wanted to spend, but I think it's worth the money considering my options in that price range that don't involve vise restoration/repair.
I picked up some Grade 8 hardware, because why not, and got it mounted this afternoon. I've not used the vise yet, so this is just my initial impressions... Note the work bench is not a permanent solution. It's something I threw together in 2020 before lumber prices went to the moon, and seemingly everything else has followed suit. But anyway....
Pro's;
- It's only a 4" vise, but it's big, thick, and it's heavy at about 40lbs.
- Jaws are smooth to open and are replaceable. They open more than enough for me.
- The anvil section is large for it's size.
- The handle is nice and solid, and large enough to clamp down hard.
- The jaw mechanism is a tube and it's sealed, so it won't get full of dust and dirt.
- It's tight. I can feel no slop in the jaw mechanism, swivel or mounting points.
Cons (which are more cosmetic than anything);
- The fit and finish is not perfect. You can see there are a few spots of paint that got thick or otherwise messed up at some point along the line.
- The edges of the anvil are not perfectly straight and were a bit jagged/rough, but nothing a few passes of a file could not smooth out.
- The jaws don't sit exactly flush or even with each another when fully closed.
- The swivel "locks" don't sit inline with the vise when tightened down, at least one of them kicks off to the side.
Overall, I'm happy with my purchase. It will suit my needs and required tasks just fine, and without having to abuse it.
I just hope it's as strong as it looks and feels.
I also purchased a 6" Doyle vise yesterday. I purchased an inside track membership to take advantage of the 20% discount. I didn't weigh the vise but it shows on the box that it weighs 68 pounds and it feels like it does. It's a heavy vise and more than adequate for what I need it for. I would advise anyone purchasing the vise to take it apart, clean it, knock some burs off and properly lube it before using it much. I don't know how well it will show in the pictures but the "lube" that is in it is dirty. It is closer to a very coarse lapping compound than it is lube. Kinda of mix of ************, mill scale, casting sand and other abrasives. Although I am happy with it for the $$$.![]()
I know, that's the wierd part. Mine felt smooth or at least I thought it did. I originally took mine apart to measure the lead screw and the area where the lead screw is retained in the front moveable jaw. I wanted to put in a thrust bearing for front to make it rotate easier and wear less. there is a thin washer there now that is really subpar. When taking it apart I noticed how much grit, slag, casting sand and steel shot was mixed in the grease. After cleaning it out and greasing it with red grease I am amazed at how much smoother the vise operates. Thrust bearing on order which will make it much better.That *****. I will definitely have to inspect mine in more detail when I get the chance. It didn't feel gritty or rough at all though.
Having to clean a new vise, or even some new tools isn’t uncommon.That *****. I will definitely have to inspect mine in more detail when I get the chance. It didn't feel gritty or rough at all though.
Could you put up a few pictures of your installation of the thrust bearing, I would like to do it to mine as wellI know, that's the wierd part. Mine felt smooth or at least I thought it did. I originally took mine apart to measure the lead screw and the area where the lead screw is retained in the front moveable jaw. I wanted to put in a thrust bearing for front to make it rotate easier and wear less. there is a thin washer there now that is really subpar. When taking it apart I noticed how much grit, slag, casting sand and steel shot was mixed in the grease. After cleaning it out and greasing it with red grease I am amazed at how much smoother the vise operates. Thrust bearing on order which will make it much better.
Good catch, I noticed it too.I am all for spending $170 on a vice, but there is no way I would spend it on a vise from HF. Subtle but important ant difference in spelling.
Check out post #36 from Boogerman. Similar process.Could you put up a few pictures of your installation of the thrust bearing, I would like to do it to mine as well![]()
Although I will be making some room for the bearing I won't have to remove much as there is almost enough slop in the lead screw to fit the bearing without machine work. If the bearing makes it way I will post pics. This will be a beater vise, well like every other vise I own.Excuse my ignorance, but how can you replace a thin washer with a roller or ball bearing thrust bearing without milling out some additional space.![]()
