I got some back in late September/early October time frame (from the vendor so date of manufacture I don't know).
One side has the UL logo and is 450V/32A
The other side (with PSE logo) is 20A/300V
Purchased at the beginning of June. 300v 20amp
I have the Wagos for #10 as well, but they are out in the shop.
| Ratings per | EN 60664 |
| Nominal voltage (II/2) | 450V |
| Rated surge voltage (II/2) | 4kV |
| Rated current | 32A |
| Legend (ratings) | (II / 2) Overvoltage category II / Pollution degree 2 |
| Approvals per | UL 486C |
| Rated voltage UL (Use Group C) | 600V |
| Rated current UL (Use Group C) | 20A |
COMPACT splicing connector (221-413) | WAGO USA
COMPACT splicing connector; 3-conductor; with operating levers; 12 AWG; transparent housing (4050821808442) Online at WAGO USA!www.wago.com
IEC Approvals
UL Approvals
Ratings per EN 60664 Nominal voltage (II/2) 450V Rated surge voltage (II/2) 4kV Rated current 32A Legend (ratings) (II / 2) Overvoltage category II / Pollution degree 2
Approvals per UL 486C Rated voltage UL (Use Group C) 600V Rated current UL (Use Group C) 20A
| Rated current UL (Use Group C) | 30A |
The 221-6 series are fine for 30amp on the #10.
Nope. These are: https://www.amazon.com/dp/B07GR8V4SV/?tag=atomicindus08-20ahh dumb question: are these the 221-6?
WAGO 221-413/996-010 3-Wire Lever Nuts Conductor Compact Splicing Connectors, 12-24 AWG (10-Pack) 60338741 - The Home Depot
Ease of use - pull the lever up, insert a conductor and push the lever back down. Available as 2-wire, 3-wire and 5-wire connectors and easily terminate conductors from 0.14 mm to 4 mm. Connect solid,www.homedepot.com
No, it's just that the original 221 series (221-41x) is limited to 12 AWG (down to 24AWG), or 0.2-4mm^2 in communist sizing.so lemme guess: 32a in the whole wide world. only 20a in the us.
Right. Because the new 221-61x will accept 10AWG (down to 20AWG), or 0.5-6mm^2 in communist sizing.The 221-6 series are fine for 30amp on the #10.
That's the 221-61x on the back-side. It corresponds with the 32A rating on the 221-41x....then what the hell are these to 41a?...
Forget the amp rating, as it's not important to you*. All you really care about is the wire size.
*Simply put, you're not going to have more than a 30A breaker, or a 24A continuous heating load on a 10AWG wire. Yes, you might be able to put a welder fed with 12AWG on a 50A breaker in some circumstances, but it's still not overloading the smaller Wago since the Wago ampacity is always higher than the admissible wire gauge. So if you're following the code with regards to the wire, and use the Wago that accepts that wire, you're all good.
