niget2002
Josephine, TX
Finished processing the rest of the mahogany for the aquarium stand. Will let it sit a few days and then plane it down and hopefully finish the stand this weekend.
MINIz guy
Philly
Pad slapped the rear brakes on my parents car. The existing pads were getting low and the rotors had no noticeable wear or ridge. Saving the front for next year as those rotors will be toast by then.
Rkcubed
Missouri
I was needing a light that was movable. So here’s my take on one.
I used a eight foot fluorescent light converted to LED. Made a frame with 3/4 conduit and made collars and hinges from some scrap pipe. I soaked the parts of the conduit in acid to remove the galvanized coating on the parts that was to be welded. Turned my trusty old stick welder to lowest setting to weld the thin conduit.1D7FD842-A9FF-4FDD-B168-41CB583494E2.jpeg96C3B58E-A569-4D90-81EF-32C509D5FBCE.jpegE7D25197-1770-4A70-B51B-F7490F93102C.jpeg
Old Man Roger
Palm Coast Florida
That’s pretty cool, but you might could have just put one of the ten or so lights you have in the background up instead. Just sayin. lol
Jim_No_Garage
Millington NJ
So I fired up a Murray Snowblower that I picked up at the curb this summer. It wasn't running properly so I did a carb swap for a Chinesium carb I had on hand. It was revving WAY TOO fast on all of the positions of the governor linkage so I think this particular carb is WAY out of adjustment. I bought it for another machine I had grabbed at the curb and it over-revved and blew the motor.
I have the Tecumseh rebuild kit for the original carb so I'll take a shot at cleaning and rebuild it and see what happens.
My plan is to sell this machine so I don't want to spend too much effort on it . . .
Cheers
Jim
Rkcubed
Missouri
If you’re talking about all the fixtures on the shel, I’m a scrounger.
I have a habit of saving stuff from jobs that can be reusable
jonshonda
Wisconsin
Cursed the fact I cannot afford, nor can I justify a new vehicle purchase while on my way to the Toyota dealership to get parts for the LCA replacement project on my GX470. Bushings are shot, and the hardware that holds them in have chemically welded themselves together.
Milwaukee Torch Carbide blades did well cutting through hardened hardware. I was really close to springing for a Milwaukee hi-torque impact but used my corded Dewalt with semi satisfactory results.
Dumped a lot of money into this vehicle lately as it has just eclipsed the 200k mark and needs to remain a dependable rig. Bit I purchased it when my last vehicle was at the 200k mark and I was just plain sick and tired of nursing it along.
Arne73
Oil change on my wife's '21 Sportage.
Bonus: found out the oil filters for my sons stolen Honda are substitute for the OEM.
Bummer: Floor jack started losing pressure in the middle of the tire rotation.
New project...
rayra
Escaped from Los Angeles
Nothing the last couple weeks. And nothing for the next couple of weeks, either. Medical trouble.
After that I have a storeroom to build in the garage, some some pull-down attic stairs to install and then some gabion wall wire cages to fabricate.
cpttuna
napoleon ohio
Re: what did you do in your garage today?
I recently inherited a million tools so I have been spending the past week going through all of them and putting sets together... I have way to many tools and not enough garage space! Sounds crazy I know but you have to see what im working with! The best part is there is alot of vintage snap on tools so ive been having a blast hooking them up!
I sort of have the same problem. i just finished cleaning out the family home in Pa after my last brother died. The garage is so full. I gave a bunch of stuff away but it seems like I have 10 of everything.
vwpieces
Hills, PA
I like the way you laid your hinges out for this glue up and will be using this later this week.
Thanks, super strong. The front and rear frames are 3 layers of 3/4in with 3rd inner layer inset 1/2in to make the inner box flush. Inner box is to support the drawers. Only part of 3rd layer started in that pic.
Also went with 4in wide on the frame boards. Already did the first one this way so I kept with it. I would do 3.5 wide if I could start over. Would save material and be just as strong for what it is. But want the pair of benches to be the same.
Oh and those 4in clamps in the corners are now $4 @ Lowes. Way better than the horrible freight clamps.
Outlander
Quebec, Canada
Not much in the Can-Am garage, my focus this week (on vacation) is my basement workshop at home.
- Cleaned off 2 benches, added fixed power bar to the "electronics" bench; found a home for the bench power supply Mrs Outlander gave me for Christmas.
- moved 3D printer beside electronics bench, rewired ethernet cabling so I could plug in the Raspberry Pi running OctoPi
- added 4 foot overhead LED lights and connected them via a smart plug (I'm always forgetting top turn off the lights)
- purged a few more bags of trash, tested all the monitors and found a dead one. Why do I keep this stuff?
- pulled out old paint cans, nowe to find somewhere to drop[ them off (probably hardware store will take them)
- cut up the plethora of boxes for equipment I kept, recycle guys will love me. Why do I keep those anyways - all I need to keep is for the on-warrantee computers
- working on my "homelab" , hopefully rack etc will be done this week (it's never really done) and I can get back to the learning phase
I better keep Mrs Outlander out of the laundry room - I used a portion for storage while I purge the shop.
When done, I'll take some photos for my gallery.
rd65
Granite Falls, WA
Went out to turn on the heat to warm things up a bit and was very surprised that it was a balmy 35* inside the shop. Was 22* outside and hasnt been above freezing in a few days. Enjoyed a beer while I let the heater run for a bit then headed back inside.
FMB4
Checked the garage temp (yesterday). Just above 40 Degs with a 19 deg ambient. The two HVAC vents in our 3 car are just enough to stay above freezing. It gets down to somewhat below zero F, but not that often. Lowest we've seen during the last 8 years was near 20 below IIRC.
PassnThru
Bowling Green KY
Worked on these screen doors I built for a side roll up door on the detached garage during the pandemic shutdown last year.
full
Initially they were great - no problems whatsoever. Then varying weather conditions and humidity levels set in and I found myself having to force the door open. I must have been a machinist in a former life because I consider 1/32 of a gap as generous. Yeah - it's not with wood that lives outside. I know that but I still insist on tight tolerances and then nature laughs at me.
Anyway - I've reworked everything to a 1/8 inch gap on this humid day and it's in the garage waiting for a sanding and repaint.
Did I learn my lesson?
Yes - yes I did. I will start with a 1/16 gap next time so it doesn't take as long when I have to fix it the next time.
As long as it seats on the door jam, outside clearance just doesn't matter a lot. Did you put lip on the left side partial door,for the man door to seat on?
Jim_No_Garage
Millington NJ
I swapped out the battery on my brother's 2016 Chevy Equinox with a Diehard AGM battery from AAP. The car is spending the winter at my house and I need it to be movable for snow removal. He bought his old company car when it came off lease and he needs to stash this car until he hopefully retires in the Spring of 22. He lives in NYC and the cost to keep the car there would be prohibitively expensive.
PassnThru
Bowling Green KY
Yes - there is a lip for the man door to seat on the partial door (that also opens - held in place by barrel bolts). The problem literally was two fold - I didn't bevel the man door for the swing in and I literally had too small of a gap to allow for expansion. It could be that my garage moves more than it should - but a wood framed vinyl sided garage will do that and when you combine that with 5 feet of wood screen doors then things just don't stay where you want them to if you don't allow for it.
full
jonshonda
Wisconsin
If you can get a return air duct in there you will really see some improvements in temps.
With a smile I parked my 14yo 200k+ mile Midwest rust belt all it's life daily driver in the garage after bringing it home from the alignment shop after replacing the lower control arms. Only to have the exhaust start rattling like a mofo.
Yes I love not having car payments, but no I don't like 14yo rust belt rigs and they work they require.
Outlander
Quebec, Canada
So far today - organized my bin of electrical parts, did more purging. Replaced broken light fixture in laundry room, with parts found in freshly cleaned bin of electrical parts. Maybe I'll do plumbing stuff next.....like I have any plumbing stuff to speak of (I **** at plumbing).
Now I await a couple of deliveries that will allow me to progress with my homelab and TV set up. Maybe I'll dust around the TV. [can't believe I just typed that]
FMB4
Prepared my Toro snow thrower for the season. Oil level check (oil was changed at the end of last season). Went over the fasteners that I could get and a splash of fresh fuel and it's good to go. Can't say same about me tho.
