1.25" Concrete Gap?
Cwb90
Question for the Pros.......Looking for a recommendation on what to use to fill a gap in my garage concrete floor. I have a gap approximately 1.25 wide by 4" deep. Is there a commercial grade epoxy filler to use that will also help bond it together? Thanks for any help.
duneslider
Riverton, Utah
That is pretty big. It would cost a fortune to fill with epoxy type stuff. I think you need to fill with some sort of a good concrete mix.
Curious what some of the concrete pros would say but that is what I would do with a gap that large.
ybnormal
is that gap IN the floor, or is it the joint space between slab pours? got a picture?
C
Cwb90
has this crack stabilized? timeframe?
Yes, its been stable for 3+ years. The problem has been resolved of the initial separation. Just wanting to know the best option to fill it. It's inside a heated garage. Thanks
Kaizen
New England
I'm thinking mechanical fasteners of some sort then hydraulic cement so it won't shrink. Short of causing more surface damage i don't know of any fastener method however.
Short term what about big foam backer rods and just have top half inch with that yellow labeled crack filler that i can never remember the name of. I'd hate to fill it and then have it move again and have to chisel out a bunch of concrete. Maybe hilti has some kind of a fastener.
Jeepster04
If you do go with some sort of flexible filler, you can use a backer rod so you dont need to fill the full depth of the gap.
