I 3D printed a stubby nozzle for the M18 Blower. Makes it even better for blowing off a just washed car.
Found the design on https://www.thingiverse.com/thing:5141506
Paul
Here is a deal on eBay for an M18 stubby nozzle.
Not mine, but cheaper than I would want to print them for. They also support a choice of colors.
Milwaukee M18 Fuel Leaf Blower Stubby Nozzle , Tip - 2724-20 | eBay
Great for blowing out cars, trucks, toolboxes, and any other areas where space is an issue. Buy more and save! This sale includes 1 shortened nozzle only.www.ebay.com
Paul
Good thought. Wonder if the electronics will prevent the safety from being bypassed. Might need to experiment with this on my whacker/trimmer first.Ya, if I was going to mount it to a swag table I'd probably delete the factory safety thing.
Yes, they do. The tool is a round plastic “stick” that is pretty worthless. Mine disappeared about 10 years ago, and I never missed it.^Don't hondas come with a stick for clearing clogs? I don't think I have ever seen a snow blower clogged up like that.
No worries. Anything that helps you to justify buying more Milwaukee tools somehow fits the general addiction theme.I found this thread after watching a "discussion" on the Deals thread regarding these attachments (mods?) for a Milwaukee blower:
Did a quick search, I'm not seeing a "Milwaukee Mods" thread, did I miss it? Or, is this the right place for such discussions?
Reason I'm asking (and maybe this is more of a custom attachments thing than a "mod" to the tools themselves)...
After cleaning up the 9-10 inches of snow yesterday, I had to clean out the snowblower augers. They weren't as bad as they usually get with deeper/wetter snow, but the cleanup takes forever (and if you skip it, the whole thing will freeze solid and either burn a belt during the next use, or melt and make a huge mess in the garage or shed).
My current tool for this job is a car snowbrush (and the plastic scraper blade has to do most of the work). A light bulb went off in my head out in the cold last night:
Is there an M18 tool that will make this quicker/easier??? Or, at least, an attachment for one?
For example, I'd buy a Hackzall at full price TODAY if I could throw something in the chuck to do the same job as that manual scraper!!!
Pics of the mess (these are from a bad storm last year), before and after cleaning...
EDIT: Maybe I could take a blade, grind off the teeth, drill some holes, and rivet a handheld scraper to it. Anyone have a better idea than fabricobbling these two things together???
Mike
Tool, Battery possibly stolen/HOT?
He mentioned it was on and started smoking. Managed to get the battery out and onto the floorYikes. What's the backstory on that?
Mike
It was definitely hot for a little bitTool, Battery possibly stolen/HOT?
i wonder if they will warranty it for the guy.He mentioned it was on and started smoking. Managed to get the battery out and onto the floor
If it's a legit battery, I'd bet they'll replace the batter and the tool to see what' going on...It was definitely hot for a little biti wonder if they will warranty it for the guy.
Yup, I'm thinking it was subject to some sort of physical damage that caused a short to the battery but who knows.
@ecotec "Pretty worthless" is a compliment to Honda for that waste of plastic!
For anyone who hasn't seen one, here's a snip (online pic, my machine is in much better shape):
@Odd-job Thank you! I was wondering whether an air hammer would be better (or even existed). Also wondered if using a Hackzall in this way would damage it.
I don't think a rotary tool (drill) would work, but I do have some on hand that I could try.
I'd definitely get use from a Hackzall for other jobs around here, maybe I should just buy one already?
Mike
Check with windshield replacement companies. The guy that came to my work had a full size sawzall with an attachment like you are describing to cut the glued in windshieldsI found this thread after watching a "discussion" on the Deals thread regarding these attachments (mods?) for a Milwaukee blower:
Mike
I've gotten several of these attachments and have been satisfied. I'm guessing one of these would work for you.Thanks guys!!!
Just watched this video, I think I'm sold! Really wish I'd had this when I stripped the (****) rug out of my old RV, and replaced the rubber roof on my current one...
Will probably add some plastic to the cutting edge, to minimize any risk of damaging the paint on the snowblower.
Mike
Thanks Rusty67. I'll give it a shot and report back.I was thinking maybe the OMT with a scraper blade on low speed might work to get the snow off?
Oddjob, I think the safety switches are just mechanical interlocks for the trigger so if you pop the case of the tool open, I think you can just remove them with their return spring and call it a day on most of the tools.
I'm pretty new to this thread, but if this is also the complaint department / wish list...
I have an M18 Rover light that I'm trying to get used to. I've used it enough times to get the dying-battery-blink you guys are describing. Wasn't expecting that, and at first thought it had fallen. Was close enough to the garage lights that I wasn't disoriented, but if I'd been running the log splitter, I wouldn't have been too happy.
Generally speaking, I love this light. However, they didn't design it to work with larger batteries very well. Yes, they fit, but block my fingers from being able to use the carry handle, and stick our too far to use the magnets properly.
Mike
The best solution is prevention. Have you done the auger mod with the rubber paddles? It takes up the clearance between the auger and the chute barrel and turns your snow blower into a more efficient no-clog machine. Plenty of info on the snowblower forum. You may also have a slipping belt.I had to clean out the snowblower augers. They weren't as bad as they usually get with deeper/wetter snow, but the cleanup takes forever (and if you skip it, the whole thing will freeze solid and either burn a belt during the next use, or melt and make a huge mess in the garage or shed).
The M18 Rover is the worst designed light by a longshot. I was one of the first to buy it, took it out of the box and instantly hated it, sold it immediately before using..... only ended up buying it again on some crazy deal I got it for like $40, think I have used it once in 3 years.
It's shorter. I think the old one was 24".Not sure whats different about the new hedge trimmer coming out.
M18 FUEL 18" Hedge Trimmer | Milwaukee Tool
MILWAUKEE® M18 FUEL™ 18" Hedge Trimmer cuts ¾” branches up to 30% faster and provides up to 2 hours of run-time per charge. The cordless hedge trimmer features a slider-crank mechanismwww.milwaukeetool.com
