Do they make a tool for these?
freudianfloyd
Nowhere
Working on a Honda motorcycle, I fought with these hose clamps the entire time. There either has to be a trick or a tool for getting these on and off. Normal pliers don't seem to work very well, the clamps just twist, and trying to work with them in a recessed area in the engine was a pain to say the least.
Meursault74
Southern California
I'm not sure if these will work for that clamp.
They have grooves for certain clamps. I bought one a little while ago. Couldn't resist it to have just in case for $5, it's a solid quality tool, the price isn't indicative of that. Be careful if this is your first time to that site. You'll lighten your wallet for sure. ;)
engineer2
Chicago burbs
They sell kits for all kinds of hose clamps. I bought one and it is quite handy.
Google hose clamp plier kit
JradM
Alberta
What about the new Knipex twin grips?
Not designed for that per se, but the multi function jaws aren't that dissimilar from pliers that are.
rd65
Granite Falls, WA
I have always used duck bill pliers, I like my snap-on better than my channel lock ones. I grab them, pinch, then twist 90* to open them a bit more.
tre873
NE TX
What about just regular needle nose pliers. A side through each hole and squeeze.
JradM
Alberta
The problem with this style of clamp is that to get it to open far enough, the holes have to almost move a little past center. I've worked with them numerous times - I don't like 'em! That means just bringing the inside edges of the rings together (like you would be doing with needle nose or snap ring pliers), doesn't open the clamp far enough - hence the "twist" rd65 mentions.
I usually just end up using combination pliers, but I think the round tip opening on the Twin Grips might be useful. I'm going to try that myself next time.
CJM8515
technically those are not reusable, they are designed to hold by spring tension and are made of such thin and cheap metal that if you open them up they may not hold as well as before.
Rc_Guy
Minnesota
how do you open them up to put them on then?
CJM8515
barely pinch them if anything. most of the time i lube up the hose with wd40 or pblaster and just slide them on. no pliers really needed. but once you squeeze them a few times it becomes pretty obvious the spring tension isnt as good as when new
ChevyEFI
Phoenix, AZ
They bave only one wire diameter. I am in disbelief Honda would use material inacapable of being snugged back up, in what appears to be a constant-tension clamp application, in which repeated expansion and contraction with variations in temp. are the norm. I like your advice on taking it gentle, but am struggling with them being non-reusable.
engineer2
Chicago burbs
If they are rusted, toss them. If you are careful, you can reuse them. The key is not to distort them. They are usually for low pressure stuff like vacuum and evap.
CJM8515
They are all over every honda powersports toy and motorcycle. I actually dont remove them really-I slip the fuel or vac hose off the barb its on-they dont hold it on really all that well. worst case lube up the hose. but literally after you puinch them (which isnt easy in the least) like 2-3x they distort or the tension becomes looser than tolerance. I can go outside right now and yank off about 10 different vac or fuel hoses they are on-on just my two atvs
Like I said-trick is to either replace them as they are cheap or slip them off not using pliers if you can.
any of these clamps are much better replacements https://www.vintagecb750.com/products/6/fuel-system/111/hose-clamps
F
freudianfloyd
Nowhere
Thank you all for the information. I had no idea they were only meant for one time use. So far, all the lines on mine are staying on. I guess time will tell.
seber
Deep East Tx.
For fuel lines, I use the spring type sheet metal only. John Deere uses the wire type on their lawnmowers. You can find a lot of threads talking about how their tractors leaked fuel onto the muffler and burned down the machine. I have no doubt the clamps were reused before that happened.
