Recip saw wire brush
NUTTSGT
Northern Central Ohio
Anyone ever try using one the wire brushes made to go in a recip saw ? Screenshot_20220113-132443.png
I'm cleaning up the rear end on the Mustang and need to wire brush inside the mounts for the lower control arms (LCA).
I can manually do it with a regular wire brush but it's going to take a bit. Curious if it would be worth it to buy one.
mike93lx
Richmond, VA
Interesting.. Never seen one of those. I wonder how it would do in cleaning paint off my brick fireplace
For 8 bucks, not much to lose in trying
N
NUTTSGT
I've seen them online, just not known anyone that has used one. Surely, somebody here at GJ has.
Yeah Mike, for $8, what am I out. . . . Nothing except the 20 minute drive there... might as well buy 2 and use military discount to boot.
FMB4
Thanks for the heads up. I never knew of, or thought of, such tool.
Voi
Western South Dakota
Kobold makes a kit with a handful of attachments, including a wire brush. As I recall the wire brush was the most useful.
Quick glance online & it appears it now has some sort of quick release chuck. Mine didn't have that.
mike93lx
Richmond, VA
For a recip saw?
All recip saws have the same attachment method. Some are tool less, old ones require an allen wrench, but the shank is the same
Voi
For a recip saw?
I didn't explain that well. My kit came with a wire brush, a file, a scraper blade & I think one other thing. All attached to my reciprocating saw chucks.
It appears the new kit has some sort of chuck extension.
Copymutt
Colorado
Can’t imagine that’s needed for a small job. Also can’t imagine the amount of airborne **** it would create for a large job.
I actually have the one pictured and have never used it.
Me too. Bought nylon and SS, knowing I will need them soon for a grout job. I have had them since Covid started. Bought a rotary nylon one too.
Someone said best to mount them upside down in saw for better brush contact to floor etc.
sparky 1971
Central Iowa
I own one, I also have the plastic bristled brush. I can't say that I have ever used either one. In fact, I forgot all about them until I saw this thread. I will say the wire brush looks and feels like it will do a hell of a job though.
Plumber4
Virginia
I've used that one and the nylon as well. They both worked well for my jobs. The metal one I used to scrape paint off metal.
Tomstir
For a recip saw?
Those do look cool. Home Depot has them with a quick release on end.
Kscardsfan
The Little Apple
I used a nylon bristled one to clean up grout in the shower when we moved into the house. Worked well on open areas but was a pain to get into tight corners etc. still beat the hell out of doing it by hand.
JradM
Alberta
I spotted those on Amazon - there's a file attachment too which seems like a neat idea. However, one of the reviews I read said you couldn't apply much pressure because of how far the file sticks out when attached to the adapter. That makes sense - it's like 1/4" hex. If the end of the file is 8-10" from where it attaches to the saw, that's a lot of leverage.
Anyone know of such a thing that doesn't use an adapter? It would be neat to attach a file to the end of my reciprocating saw.
vertguy
SE WI
I was already planning a trip to Menards and now I have a few extra items to drop into the 15% off bag :beer:
X1 Mike
Flagler, Fl
Just saw this and you'll eventually find out how they work for you, but I bought that exact same brand and am underwhelmed. Granted I am using it in a M12 Hackzall so I don't have a ton of power, but it makes it harder to put much force into it. I just end up leaving the wire brush on it and not forcing it which doesn't work as well. Wire brush takes some elbow grease. If you have a corded recip you'll be better off than I was.
N
NUTTSGT
I used my DeWalt 20V recip saw.
Impressed ? Not really.
Better than hand wire brushing ? Definitely.
Did it do everything I needed it to ? No. Im working it a pocket but I had assumed as much.
Worth the $8 cost ? I'd say yes.
What seemed to work for me was moving the brush around rather than trying to hold it in one spot.
Ton ton
Page County,VA
I appreciate the review.
bugnut
Central Ohio
Eric, I would agree completely with your assesment. I also bought the scraper blades in 2 widths and found that they are underwhelming, can really damage a surface when used at too steep of an angle. They become like a jackhammer on the surface. A variable speed sawzall helps with all of these.
N
NUTTSGT
I wanted the smaller 2" scraper but Menard's didn't have one. I'll try to find one when I need one next time.
X1 Mike
Flagler, Fl
Pretty much in line with what I found. I also got the scrub brush and have used that a bit with similar results.
foghorn1966
N. Alberta
Agree on the scraper blades Bugnut, what you said plus any side loading quickly fatigues the mounting tang, then they break.
