12v car battery tester vs. load tester?
Jacobson
There seem to be 2 main kinds.
The digital one seems to test CCA, etc.
The other kind has heat vents and does a load test.
Do you need both kinds?
Any tips on using a tool like this?
At what % do you replace a car battery ?
gmcgeo
When it comes to load testing, get your self a gold old fashion tester. the digital are not going to give the best accuracy as these
FMB4
Many of the older batt load tester designs had/have a maximum load test rating of only 500 cca. This is nowhere near high enough for most vehicles of the last 20-25 years. The best thing is to go with a minimum of 750 cca or, better yet, 1000 cca. Unfortunately, such testers are not at all cheap. This is why the algorithm load testers are gaining popularity.
engineer2
Chicago burbs
My cheap one will call a good battery good, and a bad battery bad. In between is where it is iffy.
Best to check the water levels, put on a slow charger, and re-test.
Sumboodie
AK
A tester that will handle 1000cca is about $70.
engineer2
Chicago burbs
You should to do the above before you do any load testing.
Very true. Basic maintenance first. But in reality I grab the tester first.
Anything other than good gets a maintenance check.
If in doubt, I use my load tester.
FMB4
A 12 volt 1000 amp carbon pile load tester for $70 USD? Ya, sure, and likely.
Wrench97
Southeastern Pa
The electronic ones with printers allow you to sell more batteries........................................
Used correctly the ones with the heat vents are all you need, the electronic ones are often inaccurate and call failing batteries good.
mrjaw14
Nashville, TN
the newer ones don't load test. They are a conductance tester. I have heard that for starting batteries some are ok, but for deep cycle or marine batteries they don't work well. I'm looking for a good battery tester myself and am having a hard time deciding what to get.
J
Jacobson
What the devil? Check water levels?
Batteries have been sealed for decades!
Tally ho lads!
ddawg16
S. California
Really guys?
There is no need for a 'tester'.
With the battery in the car....hook up a decent volt meter....measure the voltage.
While measuring the voltage....have someone crank the engine.
If the voltage drops below 10 volts or so...it's ether not proper charged or the battery is shot.
How F'ing hard can that be?
Sumboodie
AK
Really guys?
I often work on setups that have 2 or 3 batteries and usually don't have a helper available.
Tester is handy to see which battery is bad.
engineer2
Chicago burbs
Holy ****, is that a dot matrix printer?
Is that tester from the 1980s ?
Correct on both! It all still works, but parts are unobtanium.
The built-in battery load test works great.
Still useful on today's cars for starter, battery, alternator tests, DVOM, oscilloscope, 4 gas emissions analyzer, and maybe a few other tests. Not much need for 'big box' analyzers after OBDII came out. Perfect for old muscle cars though.
Wrench97
Southeastern Pa
I still remember the Snappy salesman trying to sell us one the hook line was how many more batteries and alternators we could sell if we had a print out on paper to give the victim ah customer......................................................still remember the garage manager telling him multiple times "We are a fleet shop we don't sell anybody anything".................................
