67carl
I'm assembling my 14" HF bandsaw and am a bit frustrated by the instructions. Parts aren't differentiated very well (or at all), some things that are supposed to be already assembled are not, while things I'm supposed to put together already are. There were a few loose bolts/washers/nuts floating around in thd box and I haven't figured out where they go yet. Steps are missing and/or so vague it's maddening.
But the main issue I'm having is wiring. The wire from the power cord is supposed to be connected to the switch terminals already, but it wasn't. The instructions say just plug in motor wires in the same positions as the power connections and give no other instruction. There's a simple pic but no terminal numbers or helpful info. I connected the motor and cord wires based on the orientation of the terminal in the drawing, but won't plug it in until confirmed.
On the back of the terminal each spade has a number - 1, 3, 4, 6. This is a simple single throw on/off switch, so SPST. But I can't find a diagram of a SPST with these four terminals. I connected motor black to 4, white to 1, power cord black to 6 and white to 3.
Thoughts?
Also, the box is **** and the wiring insulation was stripped to far back and is exposed outside the box. I'm going to replace it with something sturdy and make better connections.
Thoughts?
