Ton ton
Which ICON wrench sets do you prefer? I'm interested in the metric 5 piece reversible ratcheting flex head. Both ends ratcheting- does anyone have experience with this set? Thank you for your time.
This is the set I'm interested in.this one ?
Extra Long Professional Double Box Flex Ratcheting Wrench Set, 5-Piece
Amazing deals on this 5Pc Pro Flex Double Box Wrench Set at Harbor Freight. Quality tools & low prices.www.harborfreight.com
Yeah I saw that after the fact. Seems from other threads their 6 weeks is much longer than 6 weeks as well.................I prefer not waiting six weeks on a set of wrenches. Those Tekton wrenches do look enticing.
Those arent comparable. Non reversing and they dont have the offset on the end which makes them so valuable.Is there a specific reason you want this set? I only ask because I have been buying new tools for my shop and there are several brands available. Tekton also has a set available, they seem like a better value. After I posted this it seems they are not in stock though.
Long Flex Ratcheting Box End Wrench Set (6-Piece) | TEKTON | WRN77154
Includes: 8-19 mm (Metric). No skipped sizes. 6-point box end and 72-tooth ratchet gear. WRN77154.www.tekton.com
You are right! I did not see reversible...............now I see the button they use.Those arent comparable. Non reversing and they dont have the offset on the end which makes them so valuable.
The tekton design is a solution to a different access issue.
As far as I seen and got it 90 tooth , icon mountain matco all been 90 tooth in ones I own/used .They are as good as it gets and they are made by KABO which is a top of the line Taiwanese supplier. They have a 100 tooth mechanism rather than the normal 72 tooth used my Mountain and others. For wrenches this long that's significant. I have a set and I like them so my answer to your question is if you need them buy them. I just got a 15% off coupon on any item mailed to me by Harbor Freight about a week ago so if you're not in immediate need maybe you can wait them out for a sale.
They spline, not the worst spline drive you can come across but not great in some instances .In the picture those Icons are splines. I know some have said they are not and that picture is an error. They may make them both ways. I would just double check before you order if that is not what you want. Good Luck.
My bad.As far as I seen and got it 90 tooth , icon mountain matco all been 90 tooth in ones I own/used .
The Icons look identical to the Mountain brand that I have. And I like them. Sometimes you want the extended ring, sometimes you don't. So, to be a true GJ member, you need bothI have never had an issue with the spline drive. If I'm working on a newer car, I'm not worrying about leaving "witness marks" on bolts; I just want to remove them!
i have these. i wanted long reversible ratcheting wrenchs, these were the only options. icon, matco, mountain, ezred all seem to be made at the same factory just with different logos on them. im not a huge fan of the spline but it seems to work out and does grab pretty well even on semi rounded fasteners. the offset box end is GREAT, super useful. if i had to nit pick my least favorite feature is the revese selection button, it does get bumped and the direction changes on you. overall a nice set of wrenchs, im happy i have them.
