I bought the toptul ratchet crimper last week, and tried it out, it hasn’t really impressed me if I’m honest.
I am using TE open barrel terminals, and 0.75mm^2 wire, and a 6.35mm spade rated for 0.5-1mm^2
I tested it out in the smallest part of the die, stamped 0.5-1.
The terminal crimped, and got stuck, it was as if the die is too tight, so I tried the middle die, too loose.
I adjusted the crimp pressure, and tried another 10-15 times, no joy, it’s either far too tight, and makes the terminal get stuck, or too loose, and doesn’t hold the wire.
Does anyone have any experience with the toptul crimper?
Maybe the dies are junk?
I was going to buy a bluepoint die, as it looks like it will fit, worth a shot? £20 though is a lot to pay when I already paid nearly £100 for the toptul set.
Cheers
Cheers
