Who uses the numbers? I sure dont.
Theyre stamped steel wire strippers. Dont sweat the precision! I have a pair of the old style ones and the kurves. They strip fine. My old ones are 20 years old. Theyve always been a bit sloppy.
Good one!I wouldn’t worry about it, just like I don’t worry about proper grammar on the internet.
Alright so last night round about 5:45 ish I was pulling the front clip off my xxxxx. I was being dumb as was just disconnecting things while I was talking to a friend and boom gas (I’m assuming Freon) just engulfed me I got up and ran through the house into the back yard, I did brush my teeth and ride my mouth out cause it gave me a funny taste on my lip. I know Freon is was poisonous but I don’t know how worried I should be. It’s the next day 9:30 am an I’m currently sitting in my math class kinda panicking. What should I do? Do I go to the nurse and ask her? Do I leave school and go to the er? should I call out of work, I don’t have an simtems (sorry I’m really bad at spelling things) I mean, my mouth is a little dry in my under my lip, last night after it happened I didn’t feel anything other then the funny taste, help me out here cause I don’t wanna die I just turned 18. I think I’m going to call poison control later and see what they say. My mother said unless I start feeling weird then I’m fine but if I start feeling weird then it’s too late for me right?? I’m scared someone help
Klein Tools have "cult like" following.
I'm curious when this happened and what the problem was. I was an engineer at Klein, primarily on the low-voltage products, but had some dealings with the screwdriver side.For awhile, Klein had horrible screwdrivers but enough people jumped ship for another brand that Klein took care of the problem.
Can’t answer on an exact time the soft phillips tips began but in about 2015 or 16 the phillips drivers packaging boasted a “new improved tip” to address the issue.I'm curious when this happened and what the problem was. I was an engineer at Klein, primarily on the low-voltage products, but had some dealings with the screwdriver side.
Well there you have it. Goes back a little farther than I thought. I remember buying a couple #2 phillips and seeing the improved tip on the packaging. They have held up really well for me. They live in my electrical bag at work and a few at home.
Their side cutters are sloppy, their bags are poorly made.
Did you notice that the lettering on the right side of your "better aligned" pair is less opaque than the left side? Better alignment, less visibility! Just can't win.the old packaged version had the numbers aligned fairly well ,acceptable any ways. so i bought em and will give my misaligned ones to a co worker or something lol.,
It probably started about 15 years ago, but has been taken care of in the last five years. I was probably warrantying a #2 Philips and #2 Robertson every two months. The straight blades were ok, but the handles of all of them were junk. I don't know what the new grip was made out of, but it seemed to wear off. That was when they went from Klein tools printed in yellow right on the handle (the good stuff) to the raised letters (the junk). Now the quality is back up, I wind up losing my screwdrivers before I have a chance to wear them out.I'm curious when this happened and what the problem was. I was an engineer at Klein, primarily on the low-voltage products, but had some dealings with the screwdriver side.
Bubba this thread is nonsense. Klein puts the markings on them,that way for a reason.Stumbled across this thread. I know it's old, but the OP is being extraordinarily nit-picky. The markings are printed on an assembly line, so sometimes they are not perfect. This is the case for every single brand of stamped wire strippers I have ever seen. It doesn't matter, because the markings are *stamped* on the other side, which would be far more accurate. No one uses the markings anyway. They just fit the wire into whatever notch works best. It's the stripping and cutting performance that is important.
Besides, Imperial is the company that manufactures these, and they also do so for many other brands including Ideal, Channellock, Craftsman (Sears), and Stanley, among others.
Klein has a wide range of strippers including some that they make in-house. Those are forged and heavier duty. Judging an entire brand on one tool that isn't even made by them is a bit ridiculous. These are tools, not jewelry.
As for their screwdrivers - I've never had a problem with them. I do wish they had kept the old cushion handles with the yellow lettering, which were much more comfortable. I've never had a problem with the tips, though.
Their standalone drivers are all made in the USA. Most of their multi-bit drivers are made in Taiwan, though some I believe, like the 10-in-1 and 11-and-1 are assembled here, and I believe several have USA-made handles.Which drivers?
Homedepot is still saying their rubber handled are Made in USA??
Yet. It's not the democracy it was a few year ago.Taiwan is not China.
1923? Dang Slew! I have my Dad's and Grandad's but not that old. I still use them every once in a while.Hmm, my oldest perfectly serviceable Klein pliers are from 1923, so it will take up to 100 years to see if the late product is comparable, and I'm pretty sure I won't live long enough to do it.
Advice?
