Ran out of wire ties
FredWanaker
NorCal
Well, finally ran out of wire ties building a blueberry cage to keep the birds out. What material and brand holds up well in the sun? I use them from everything from wire bundles around the home theater, automotive wire bundles, to holding concrete wire up for the pea and bean trellises. Something that doesn't rot in the sun in six months but aren't outrageously expensive either.
Bucko
Usually the black ones hold up better than the white. You want to look for UV rated or UV resistant.
On a side note a zip tie gun is a nice little tool to have. I keep mine in the same container as my zip ties. The one I have is similar to the one attached.
Cable Tie Gun - Fastening and Cutting Tool with Steel Handle Special for Nylon Cable Tie Fasten and Cut Cables in Blue https://www.amazon.com/dp/B07G5X7DMC/?tag=atomicindus08-20
AE2
Atchison KS
Don't buy the smart electrician brand from Menards. Last few packages I have bought have broken right out of the package. Literally snap in two when you bend them.
NUTTSGT
Northern Central Ohio
Had the same issue with ones I bought at HF.
I have used some of the SE brand from Menards and worked ok for me but I bought them a few years ago.
F
FredWanaker
NorCal
I ask because the last couple I bought break right out of the package, and they fall apart in the sun. One brand will give the plastic and say UV resistant then another brand with the same plastic type will say not UV resistant. I don't want to use wire or rebar ties,
LB-1911
Northwestern Il.
One option rated UV resistant
manwithtools
Lebanon, TN
reader2580
Minneapolis, MN
I bought Xtreme cable ties from Menards for bundling wire on my solar system. They are supposed to be more UV resistant and handle more extreme temperatures.
The best would be stainless cable ties, but they cost between 20 cents and $1 each.
F
FredWanaker
NorCal
I have stainless ones but they rely on being bent to lock. I don't want to slice my arms if I bump into one. I'll look at Tiewraps.com to see what they have. .
manwithtools
Lebanon, TN
If you use a lot of tie wraps, a tie wrap gun is a great tool to have, it avoids the cut arms and hands. A good one is not inexpensive, but worth every penny compared to the cheap copies that almost do the job. I have this one: Tie Wrap Gun
F
FredWanaker
NorCal
I priced them, $63 for 200 shipped. too much. I'll just do the $10 bag at Lowes for indoor outdoor UV resistant 8" ties. I can get 50 for less than the shipping at that .com source. Not meaning to cheap out but I use a lot of ties for things then cut then 90 days later to do something else with some wiring under the desk or something. I also use velcro where appropriate on wiring.
reader2580
Minneapolis, MN
I like those Ty-Rap cable ties, but they are so expensive. I save the good Ty-Rap cable ties for things where the cable ties will be there long term and coming loose could be an issue.
ChefRex
Second the Thomas and Betts, I also reuse longer tyes all the time.
  • Like
Reactions: 555
rcktpwrd
Raleigh, NC
Check out monoprice.com for great prices on zip-ties. Typically the white ones are not UV resistant, most of the colored ones are.
nadogail
Coronado, CA
I have used Panduit Stainless wire ties when working on a Hot Laminating Circuit board press. Never had a problem with the heat or oxidation.
bonneyman
Desert SW
I've used these UV resistant ties for years on A/C condensing unit fan motor. To secure the wire leads and keep them from falling into the blade. Lasted several years in the Tucson sun. Strong, inexpensive, easy to tighten, came in several lengths for different applications. FWIW
But be aware they're only rated at UV resistant, not UV proof. They generally didn't break on their own, but if you hit them or tried adjusting them after a couple of years they could break. No problem - I just replaced them on the spot!
Sumboodie
AK
I've never heard of zip ties called wire ties.
Took me several posts to figure it out!
Firebrick43
West central Indiana
What are rebar ties?
All I ever used were the pieces of wire with the twisty handle
used with a tool like this
Very fast, and very uv resistant. No need to clip the ends either as they are not sharp.
yes, please wrap your automotive wires with one and see what happens when it rubs thru.
No one said to use them on automotive wires Fred, they were talking about your blueberry cages, save the zip ties for the wires.
bwringer
Indianapolis
Thomas and Betts Ty-raps, they are UV resistant and have a stainless steel retainer.
If your zip tie makes a zipping sound they're a POS.
Same. Yes, they are absolutely worth the extra money. I buy mine in bags from a local racing supplier, Earl's.
I've given up on the lesser imitations. Life is just too short to **** around wondering whether your crappy "zip-ties" are going to hold long-term.
If you need to use a lot in some consistent and un-challenging application, then I guess you could save a few bucks on a bag of reasonably decent cheapies.
My use cases are quite varied; I'm usually using a few at a time in all sorts of situations, usually motorcycles. So it's important that the wire bundles or whatever stay where I want hem, and it's well worth using the absolute best knowing they'll stand up to heat, cold, sun, and vibration. The biggest issues I've had with the imitations is that they get brittle, and some are too brittle right out of the bag.
yugami
Nylon gets brittle when it dries out, if you speak them in water they'll be like new
bwringer
Indianapolis
I've looked at Earls and can't find them on their site. What are they under?
The Earls' Indy website is a complete dumpster fire; they're, uh, more of an in-person type of place. The racing world is very old-school.
They're close to the IMS track down in Speedway and cater to all the race and motorsports teams in the area. If you go there in person, they're hanging on the wall and you grab what you need.
If there's a similar race shop around you, I'd look there. Or order them from Cable Ties Unlimited:
Tie Wraps.com doesn't seem to have genuine T&B, but they do have "stainless tooth" cable ties:
Pegasus Auto Racing, and I'm sure many other racing suppliers, stock T&B:
no704
Nylon drying out al was makes me laughUsed to work at a van up fitter. The flexible wire chases were prone to getting broken. The senior engineer ordered them to be stored in ziplock bags with a couple oz of water.
Firebrick43
Store your weed wacker line in water and it will last much longer in use. Nylon is hydroscopic somewhat and it does affect its flexibility.
Cardboard Man
Go to tractor supply or equivalent and buy a roll of aluminum fence wire for your outside applications. It won't rot or rust. Save the plastic zip ties for jobs that won't see sunlight.
jagboy69
Texas!
lol... Is there anything scamazon does not sell? They sell 41 thou heavy stuff. You can fix a whole lotta broken **** for 14bucks! I had a link up here but it turned generic. :-/ And no it wasn't an affiliate link. I don't do that BS!
