If you haven't already purchased a unit, there are a few considerations you should makeWe recently sold our 1980 John Deere 400 25 hp. - K582 - Garden tractor.
From what I have been around, we want to stay in the 25 hp. Or bigger range.
We are wanting to replace it with a diesel, not too much bigger/heavier. With 4x4, rear pto & 3 point. Possibly a loader.
The 400 had a 60" deck. A 54" belly or front deck would suffice.
We are not choosey on brands.
We have had the JD 400 since 1985 and really have no clue what is available or what we should be looking for.
We know we want tires at least as big as the 400 had or bigger.
Our yard can be soft on occassion.
We have a couple older Toro front decks. 223D and 325D for mowing.
We are not scared of old. And want pre-emissions. Not really sure what years that includes.
Links or PMs appreciated, if you know of something specific.
Still shopping. But not pressed for time. So far my favorite find would be an old JD955 with low hours. About impossible in this market.If you haven't already purchased a unit, there are a few considerations you should make
1. How easy are the attachments to change, seconds, minutes or hours
2. Ease of use, comfort to operate & handy controls that are easy to use & close at hand - no reaching req'd
3. Variety of attachments available
4. Ease of maintenaince - how easy is it to change/add oil, fuel, coolant, parts accessability, in stock or need to be ordered & WAIT!!
5. How long do you expect it to last
6. Resale value when you either what to upgrade or sell when you no longer require that type of epuipment, does it have value or is it worthless
Many units that may cost less can save you $$ up front but will aggrivate you every time you use it. If aggrivation is ok then save 10%-20% buying a bargain
If you want to pat yourself on your back every time you use it because it's a wonderful unit then spend a bit more so you can do just that
It takes about 45 seconds to remove or re-install the loader on my JD 3046 tractor. I've had a JD 400 - NOT RECOMMENDED
a JD 2305 & a JD 2720 & now the JD 3046 - all the accessories are super easy to install or remove - no pins to line up, nothing to hump around
Almost all other brands are not that user friendly when installing / removing attachments.
They all work reasonably well when they're new but....
Make sure the sales person will show you how to operate everything & not just tell you how to operate & install/remove attachments
It's a big investment & my best advise it to buy 1 or 2 sizes larger than you require today so you won't have to upgrade as often because you most likely will want a more powerful unit sooner than one realizes
Check out new prices in your area & then used prices to determine your end cost of ownership
1st choice John Deere
2nd choice Kubota
3rd choice is a **** shoot at the best of times
Happy shopping
Is there a diesel 4x4 version?Couple years ago, I bought a 2015 JD X738, just because I wanted a tractor to play with, that was larger than the small Cubs I was playing with. It was 5 years old with ~130 hours on it and came with a 54" deck, which I really didn't want. The dealer added a 54" snow blade, all for around $10,000. Last year, I added an aftermarket fel for another $3,000. It ticked all the boxes I had for my use.![]()
That's a cool little machine. I'd use the hell out of something like thatCouple years ago, I bought a 2015 JD X738, just because I wanted a tractor to play with, that was larger than the small Cubs I was playing with. It was 5 years old with ~130 hours on it and came with a 54" deck, which I really didn't want. The dealer added a 54" snow blade, all for around $10,000. Last year, I added an aftermarket fel for another $3,000. It ticked all the boxes I had for my use.![]()
I did last summer, just wish I'd bought one a few years ago when I hauled 7 tons of rockl. Last year, I hauled 9 tons of fill dirt to level the edge of a ravine, plus used it to lift two small bridges I replaced over my creek. We season our firewood down by the creek, then haul it to the wood shed with the end loader and a wagon full in the fall, plus other jobs, of course. I like it.That's a cool little machine. I'd use the hell out of something like that
Tractorhouse.com ?There is another site but can't remember what it is right now.![]()
Used Equipment for Agriculture, Construction & Forestry | MachineFinder
Discover used equipment from John Deere, such as lawn mowers, tractors, UTVs & agriculture equipment. Search the inventory of John Deere dealers near you.www.machinefinder.com
Holy smokes. 8k for a 16 year old tractor without any attachments besides a deck? That's nutsMachinery Pete:
2006 John Deere X748 Lawn and Garden - Isanti, Minnesota | $8,295 | Machinery Pete
2006 John Deere X748 lawn and garden. Browse the most popular brands and models at the best prices on Machinery Pete.www.machinerypete.com
That does seem high. I purchased my 2011 with a 54” deck for $5k 4 or 5 years ago. I got a great deal on it though. Also, I’m not sure why that machine is listed as 2 wheel drive. The 2WD would have been the x728.Holy smokes. 8k for a 16 year old tractor without any attachments besides a deck? That's nuts
This is the problem in todays market, especially in the scut / cut market. What I observed was out of warranty equipment going for almost new prices. Kubota warranty is 6 years. In 6 years a lot use / abuse can occur. At that point the savings, what little it might be, can be easily consumed in maintenance and possible repair costs. For the couple extra thousand the warranty is cheap insurance and guarantees low hour operation.Holy smokes. 8k for a 16 year old tractor without any attachments besides a deck? That's nuts
We finally went out looking yesterday. We liked the B2601. Just the right size for what we need. Now, if they could knock $10,000 off to get to a reasonable price.Look at the B series Kubota's, specifically a 2601 or 2301. Both are under the HP limit for emissions. I have one the I purchased new back in 2016 after analyzing every tractor around for over a year. This is a tough market to purchase equipment in, everything is going for top dollar. My machine new with the backhoe w thumb, loader w third function, and 54" mid mower deck was just over 27K. You can knock that down quite a bit if you don't need the backhoe.
They will do a ton of work, mine has moved hundreds of tons of material around the property while building my shop.![]()
You forgot about Kubotas treadle pedal design that *****!In searches the only things advised were the seat ***** and they could use rear wheel spacers.
It still bothers me that I can buy a 200 hp tractor cheaper than a garden tractor. Might ought to buy goats or sheep and some electric fence
Just saw one yesterday listed for $12,000. 100 hp tractors are everywhere for under $20,000You forgot about Kubotas treadle pedal design that *****!
Be careful with wheel spacers if you have a mid mount mower deck, it can cause clearance issues.
If you can find a good condition 200hp tractor for less than a CUT I’d be all over that! Although you’ll probably find the CUT more useful.
That was my plan. I already have the front deck Toros.I have never had an issue with the seat on mine, but I have the swivel seat since the backhoe is there, I think it is different if there is no hoe. As nice as it is to have one machine that does everything, in retrospect I should have purchased three different machines. A zero turn mower to do the lawn, and old mini excavator for digging, and an old skid steer for the loader/fork work.
At the time had I done some searching I probably would have spent the same money and had machines that were better at doing all those tasks, although the Kubota holds its own and does get a lot of use, and it was new, and I could finance it at 0% instead of outlaying 30k in cash, the gains I've made on having that money invested over the past 5 years have covered a good portion on the cost of the machine.
Yep. I understand that we have been averaging 5% for several years.I have never had an issue with the seat on mine, but I have the swivel seat since the backhoe is there, I think it is different if there is no hoe. As nice as it is to have one machine that does everything, in retrospect I should have purchased three different machines. A zero turn mower to do the lawn, and old mini excavator for digging, and an old skid steer for the loader/fork work.
Did you end up buying a 2601?Yep. I understand that we have been averaging 5% for several years.
I still had a lot of trouble buying new. And to kick it, I don't care for the tractor.
The 26 HP is undersized for a lot of stuff and the LX2610 tractor is oversized for the HP.
I would have been better served with a smaller garden tractor - like a 455. Or a similar sized older tractor with more HP. Like a JD 955.
But we couldn't find anything for what I considered a reasonable price. Especially since I am not able to work on much right now. Or possibly ever again. Everything is left up to my wife.
Except I about killed her with the Kubota already.
I hope I get used to this thing. Way to jerky for me
LX2610.Did you end up buying a 2601?
If you recognize all those faults in 15 minutes, they must be pretty glaring.How can you be sure of all those faults after 15 minutes?
I guess I am wondering why you bought it if they were so easy to identify.If you recognize all those faults in 15 minutes, they must be pretty glaring.
Most we knew before purchase.
Having had it this long, and not been able to use it, is a kick in the crotch. Wife made the first payment. I would have sent it back and moved on.
For what you want to do, wouldn't a small loader be incredibly helpful? That 318 sounds very pretty, but for all the reasons you listed, it doesn't feel like the right machineLots of SCUTS on this thread. I'm looking to step up from my x320 to a beefier tractor to maintain my private gravel lane, shuffler a car hauler around, and cut grass/haul mulch/stone.
I found a x730 that has 1250 hours on it and was rode hard and put away wet! They still want 4,900 for it. It needs tires and the steering column is loose, front grill is cracked badly and needs replacing. So I figure 1,000 additional for me to replace the tires, grill, and fix the steering issues. so nearly 6k for an overworked 'newer' tractor.
I also found a 'frame-off' fully restored 1989 318 plus a JD Model 80 cart for 4,300. The guy got the tractor from his dad with 900 hours. He and his brother tore down fully, sandblasted everything metal and had an auto painter repaint every piece. The tore the motor down sent it out to be machined and rebuilt it fully. He sent me a 6 page spreadsheet that lists all the parts, part numbers, where purchased, and date. It also has one page of notes entries on the status by date and other related bits of information.
This thing looks factory new. He is being transferred over seas and when he comes back is not going to keep is current suburban house, so he is selling his stuff. His brother restored another 318 so he does not want this one. He has every manual/parts book there is, plus 3 boxes of spares, some tools he has for it, and a couple of containers of hydraulic fluid.
I've always wanted a 318, but perhaps I'm too caught in the "legendary" aspect of that tractor. It is over 30 years old, but full refreshed and ready to rock again.
A buddy keeps telling me to find a kubota 4x4, but that seems like overkill. I think a decent x7 series will do the job, but I'm trying to stay around 5k, so I think I need to up my budget.For what you want to do, wouldn't a small loader be incredibly helpful? That 318 sounds very pretty, but for all the reasons you listed, it doesn't feel like the right machine
After seeing someone post a pic of a x738 with a loader here, I really want one.A buddy keeps telling me to find a kubota 4x4, but that seems like overkill. I think a decent x7 series will do the job, but I'm trying to stay around 5k, so I think I need to up my budget.
That would have worked for us. Or a JD 455.After seeing someone post a pic of a x738 with a loader here, I really want one.
