Auto Shop ceiling. Black roofing?
robbiegtp
I have small 4 bay auto shop. Right now, the ceiling is just showing the insulation. I want to make it black ceiling. Was thinking about metal roofing? What are my options? Thanks!image0 (4).jpeg
Wrench97
Southeastern Pa
Drywall would be the cheapest route or just add hard foam sheet insulation and paint it your color of choice, silver or white would make the shop brighter but you'll need to keep it clean, black makes the shop darker but hides the dirt/soot/exhaust grime.
NUTTSGT
Northern Central Ohio
Kevin did a black ceiling but he chooses not to post any more. I'm not sure if his garage thread is still intact for pictures.
npp
My opinion, definitely not black, as lite as you get get it to reflect as much light as you can. Worked as a tech for 47 years and a shop can’t be too bright.
kbs2244
I agree with the white opinion
but I have seen a lot of black painted ceiling tiles in a number of places
you just need a ledge at the bottom of your cross pieces to set them on
they would be easy to replace if you decided it was too dark
Tbender78
Boston area
Metal roofing metal is a great choice for ceilings. Not the cheapest but looks great. I just did my 40x60 with 12 1/2 foot ceilings. I went with 20’ panels which were a little tough to handle with 3 people.
mike93lx
Richmond, VA
Look up "liner panel". Ultimately if you want black, go for it. Needing to add some lighting is far from the worst thing in the world. Looks like a lighting update is probably justified anyway.
Whatever you choose, a finished ceiling would definitely help appearance and make the space feel nicer.
Plastikosmd
Cool vibe but everyplace that I have been with a black ceiling means I have to use my iPhone to read the menu
K'ledgeBldr
Johns Creek, GA
White has reflective properties- so you’re not adding to the budget for more lighting.
As far as material, I would take whatever material gives me the best benefits- drywall. Not only is it “cheap”, but it probably has the best fire protection AND sound attenuation. Shops are noisy places to begin with. I can only imagine what they’re like with a metal ceiling(?).
kwb
PNW
Sheetrock, fire tape, paint black.
Appears to be a commercial space, that means the fire marshal will walk through periodically. Just do it to code.
kbs2244
.when I said "ceiling tiles" I was reffering to a suspended ceiling tile
rayra
Escaped from Los Angeles
yeah. Usually bars and nightclubs. Not a shop where every bit of light you can muster is a useful thing.
FredWanaker
NorCal
around here black widow spiders are attracted to car parts, garages, and black surfaces. Nothing like the feel of one of those sticky crinkly webs hanging between the ceiling and a tool box.
mike93lx
Richmond, VA
That would be a hell of a web. Ceiling looks at least 13 ft high
Blackbyrd
TN
I have an exposed ceiling in my basement garage I recently painted flat black. Hides everything and doesn't impact light. Yes black is not reflective, but the lights are pointed at the floor not the ceiling.
Used dryfall paint. It was $80 forna 5 gallon bucket and it covered the space.
markrenner371
looking cool if you fit lighting ontop diffrenent colour
R
robbiegtp
I was open to all different options. Yes white would reflect lighting but most modern shops are using black ceilings to hide all the grim from everyday work. New lighting was going to be installed so that’s not an issue. Thanks guys!
strokinhorns
St Paul, Oregon
i have a black skrim covering the insulation on my ceiling. typically it is foil or white and used in warehouses.
Blackbyrd
TN
Here's how mine turned out
