I have a couple of specific questions about some of the mods done to the HF floor blast cabinet. I have read thru the sticky at the top and wasnt sure if I should start a new thread or add to the existing. If this needs moved, delete it and I can post there.
First question is regarding the added air baffle and the difference in using the left side or back as the suction port. I have a baffle for the left side that is almost as long as the one in the back. I see some people attaching them angled towards the front and some straight down. It would be easier to use the left side as my suction port plus allow the cabinet to sit closer to the wall. I understand you are trying to create a draw for the dust to improve vision in the cabinet. Would there be much difference using the left side with the baffle? Angled towards the front or straight down from anybody that has done it?
Second question is regarding the glass. My unit is the older welded together cabinet. It has a piece of plexi on the outside followed by a piece of glass that has the tearoff protector. I plan on making the wire screen frame to make the glass last longer. Whats the purpose of the plexi on the outside? For the guys that just replace the glass when its fogged, are you adding a second piece of glass in front of the original? Or just replacing the one piece when its fogged?
Thanks
Thanks
