Any slick way to pull up a dozen solid rods in the ground before I rent an excavator, thinking about 8' in length.
Farm jack.Yes vertical with at least 48" above ground, not sure how long they are until I can remove one.
Farm jack.
You may be able to get bite with a length of chain or a strap.
The attachment I mention is a stout piece of metal with an oversize/oval hole in one end. Lay it horizontal, slip over the bar. When you pull up the opposite end it wedges on the bar and allows you to pull up.
