rmack898
I did a search for shop tips/tricks in this forum and didn't see anything.
Shop secrets are those little things that are so simple, and make an otherwise difficult task, easy. At the first shop I worked at when I was 17, there was an old guy named Artie that always had a trick up his sleeve for getting a difficult job done. I can't even begin to remember how many things he taught me, but all the little tid bits of knowledge he passed on to me have made me a better mechanic/machinist/fabricator. I'm always eager to pass on what I've learned over the years to others that I work with like Artie did with me.
So here's a shop secret that I got from a guy named Ray on the PM forum about 10 years ago.
If you have a horizontal band saw in your shop, you need to make this little tool.
Find a piece of large sch 40 or 80 pipe. 4" pipe would work but 6" would be better. Slice off a 1" piece off the pipe. Drill a 3/4" hole through the wall of the 1" slice of pipe, and then cut the slice in half with the cut going right through the center of the 3/4" hole. Now the tool is complete.
Your new tool is used to cut short pieces on the band saw that will not fit in the vise. The side of the tool with the half of 3/4" hole is used for round stock. Pictures are worth than my rambling words so here's how it works.
In the last picture, I'm cutting a 3/4x1" piece of aluminum that is 2" long in half on an Ellis 1800
Please add any shop secrets you have to this thread.
I think I get it, but a visual would be super helpful!
... Steve
