LED Mini Flood Light flickering
Alchase
Harrah, Oklahoma
I bought this house in 2015, replaced all the light bulbs in the house with LEDs.
Now I have one (of 12) of my LED Mini-floods in my kitchen, that flickers when the AC or Heat comes on?
They have worked perfectly for years.
I tried replacing with a new bulb, same flicker happens.
Any ideas where to look to solve this issue?
Pantsfall_McFixit
It may seem to be a silly question, but what kind of flickering is it? Is it constant flickering, or just one short flicker for a tenth of a second, etc?
BillK
Beautiful Southern Maryland
Is it on the same breaker as the heat ? LED's can be picky about voltage and noise on the line. It might be the fixture. Is the lamp making good contact in the fixture ? Mybe check the fixture wiring ?
nadogail
Coronado, CA
LED Lighting has demonstrated a great sensitivity to voltage fluctuations. Incandescent lamps tend to "ride through" short dips, but not so with the LEDs.
ycgoat
S.E. Va
IF it happens every time the AC comes on could also be a bad bulb socket connection loosening from a vibration
A
Alchase
Harrah, Oklahoma
it is kinda random, it only does it when the AC or heat comes on.
The connection to the cans is up in the attic.
I need to get up there are chech the connections.
A
Alchase
Harrah, Oklahoma
Update!
After Silverplate said:
"Non-Dimmable led bulbs do not flicker."
I looked in my stash of mini-Floods, looking for a Non-Dimmable bulb.
Then I got an idea, Why I had not tried this before, I have no clue. Talk about a total Brainfart!
I took a bulb that was functioning in a different socket, and placed it in the socket with the flickering problem. No Flicker!
I then put the flickering bulb, and the bulb I was trying to replace it with, each in the known good socket.
Both Flickered!
So I actually had two bad bulbs, the original and the one I was trying to replace it with.
Now all is as it should be.
thank you to everyone who replied!
