Switch/plug combo wiring
mkbug
Vacaville, CA
I thought I understood how this should work. But apparently not. I can't get the switch to control the plug. I have the black coming into the switch terminal. The switch didn't control the plug. So I then removed the tab. Still the plug was hot regardless of the switch. The white is connected into the plug terminal.
What am I missing?
yatg
Southern Oregon
Last picture - you don't have anything connected to the left side of the switch? That should be your incoming line power.
Break off the fin, which you already did. This makes the switch and receptacle independent of each other.
Jumper from right side of switch to right side of receptacle.
Neutral to left side of receptacle.
Blkhawk870
If you're looking for this switch to control the attached outlet, you would need a black wire from the brass screw on top terminal of the switch to the black screw of the outlet.
Blkhawk870
I forgot to mention the black wire from the cord should be only connected to the black terminal at the switch.
mkbug
Vacaville, CA
Where I have gone wrong? - Switch still doesn't control the receptacle.
mkbug
Vacaville, CA
Thank you YATG & Blkhawk870. This was the last part to my Stock Tank Pool heater.
Jim greengo
Behind my house
You've bypassed the switch,run the cord to brass screw top left.
Since you cut the jumper on right,you'll need to run a jumper wire from top right screw to bottom right screw to energize outlet when switch is turned on.
Your neutral wire will go bottom left to complete the circuit.
wyliesdiesels
Modesto, CA
Why did you break the tab off? Shouldve left that on and just moved your incoming hot to the brass screw on the left side.
Also, those screw terminals are not rated for finely stranded wire thats found in cordage.
If you insist on using the cordage, i would twist the strands tight and then add some solder to them to make it one strand.
alfredeneuman
Fullerton, CA
All of this right/left stuff is nonsense without some context.
It depends on whether your view is from the back or the front and what direction the device is oriented (sw. on top or recp)
sparky 1971
Central Iowa
I think he has it figured out now but how's this?
The side with the silver and brass screw is the line (input) side, just like in the picture on the box. Put the neutral (white) on the silver screw and the hot (black) on the brass colored screw, and the ground on the green screw. That would have taken care of it, but since the tab between the terminals on the other side has been removed, jump a short piece of black wire between those two screws. You should probably use some forked crimp on terminals since that device isn't made for stranded wire.
wyliesdiesels
Modesto, CA
Theres only one brand of receptacles that are listed for fork terminals- hubbel.
