Lumber prices
Sturgeon
W. Mt.
Starting a garage soon, waiting on weather to swing around. Can't get rock until road restrictions lifted, so visited lumber yard yesterday asking when lumber prices would reflect what you see on the open markets and left more confused than informed? Also adding to the length of the garage to 52' and estimater because of cost is suggesting instead of 20' top and bottom plates to use 14' stock instead and I'm thinking there goes any chance of straight walls, not to mention integrity. Fourteen foot long walls would be a lot more manageable, just not sure it would be worth the trouble? What's your guy's thoughts. Thanks
mwalsh9152
Lumber prices at local yards will drop much slower than HD, Lowes etc. They put their orders in at the higher price, so they have to burn through that lumber first. When prices start dropping I will wait a while before my local yards prices are in line with the box stores before buying from them. I want to give them my business, but I'm not willing to wait for my profit margin to improve on their behalf.
rancherbill
Foothills County, Alberta, Canada
Wow 20' lumber, I don't think I've ever seen it that long. Sixteen is common and 14' will work and you will get straight walls. It is done EVERY DAY.
I believe the pricing is just gouging right now and who knows when it will stop.
Sturgeon
W. Mt.
My thoughts as well, l'm just peanuts to these guy's but my observation was don't count on them lowering their prices. Salesman talked over my head, frustrating and using 14' instead of 20' plates sounds bad?
reader2580
Minneapolis, MN
A 2x6 20 foot costs about $10 more than a 2x6 16 foot after accounting for the extra four feet. I agree with the post about being able to get straight walls with 14 foot lumber, but the cost isn't horrible if you want to use 20 foot lumber.
Sturgeon
W. Mt.
Surprisingly I spoke with a lot smaller lumber yard and they said their prices are going down ware as the two biggest yards are stuck at $1600.00 + per thousand and blaming everything under the sun.
loganb
Omaha, NE
If you want really straight and tall walls, Google VersaStud, LVL at standard framing lumber sizes designed for direct replacement of 2x4, 2x6 etc. Especially nice for tall walls and the roughly 70% improvement in resistance to bending may allow to reduce some framing to help offset the higher cost
Bretny
Dutchess county NY
Big box stores even sell 20' and I bet can get 24' if you ask. Local smaller lumber yards would stock upto 24'.
Just because you dont see it on the shelf dosnt mean it's not at the store.
rancherbill
Here, wall segments are built on the ground, sheeted and covered with Tyvek than then stood up. Then the wall get the top plate. The walls end up straight.
In the lumber yard the rate of sale 24' would be slow and they would end up like pretzels, especially if you were at Home Depot. With high run rate products like 16' they probably would be straight.
reader2580
Minneapolis, MN
I have used these for a few small walls where I needed less than a dozen studs, but the cost is about double of regular framing lumber. Back when a premium 2x4 at Menards cost about $3 the LSL 2x4s cost $7 or $8 each.
Great to work with, but a large cost premium. They are usually used for tall walls where standard framing lumber isn't strong enough for the application. My brother's new house has a lot of LSL lumber in 2x8 sizes because regular lumber was not strong enough.
loganb
Omaha, NE
Agree. For standard construction or normal walls the cost premium is steep. I have talked to a couple smaller, premium home builders who exclusively use them on walls at 10' or taller as they said the savings in time to drywall makes up for the cost due to how much less mudding and sanding it takes due to things being straight.
Sturgeon
W. Mt.
Thanks everyone, great imformation. I'm not a framer but have been around some great old framers and twenty foot plates will be the ones I go with. Not knocking lumber estimater guy but I was just trying to see how there prices work and everything went side ways and the two things I got were 1. don't stock 20' and to much $$$. Thanks
pfmg
Billerica, MA
In the process of an addition on top of my garage now, greatroom for the family, and a high ceiling bay with storage for me. Builder is doing the outside, ill finish the inside. Almost died when i went to get some strapping, $11 a piece for 16 footers, use to buy a bundle of 10 for that price. Builder say his lumber cost went up $6500 from the time he did the quote to when we started.
Innovate1
As some others have said there is no real reason to go with 20' lumber. If I understood what you said there was a premium for that length that was more than just accounting for the additional length. 16' is usually more common. The top plate joints should be staggered so you have lots of overlap.
Bucko
My barometer for lumber prices is the standard 2x4x8 lowes item #6005. I don't believe all regions use that sku but I'm most concerned about the cost at store level. I've watched it go from $3.48 up to $8.48 and is currently at $6.98. I have a few projects that are not a necessity and when the price is where I want it I will do them.
I feel real bad for people that don't have a choice. My neighbors got quoted $2.25 sq' to build a house on the lot they already own so they is waiting.
yeldogt
They are a dream to build with IMO. Stable and uniform ... straight and stay straight. My current project is tight and I have a lot of pocket doors -- no room for twisting. They make it easy. They also match up to the I beams perfectly -- nice and smooth. I always use 5/8 rock ... but with the quality of the drywall guys today -- these small things are becoming more important
MongoTA
CT
It's not just the cost premium of buying 20' sticks, but what if you go with 20s and they themselves are not perfectly straight? Personally, I use 16' sticks for top plates. The cost vs benefit is appropriate. Plus you'll be stringing the top plates straight with bracing as you build. If you were ordering engineered lumber for plates, then sure, go as long as you want, as they will be straight.
walrus
Maine
I paid 8 dollars and change for KD 2 by 4 by 8 ft studs the other day, in Maine where the state is 95% forest. Sawmillis are shut down all over the place here and prices are thru the roof. Makes no sense. 1/2 cdx plywood is 62.50 a sht
reader2580
Minneapolis, MN
You would think sawmills would be pumping out every bit they can to take advantage of high prices. On the other hand, more supply should make prices drop so opening a closed sawmill may not make sense. You also have to be able to hire to open a sawmill.
Showkey
"MEMBER EMERITUS"
Wausau WI
Theres no shortage of actual lumber when the box stores have 1000’s sheets and 1000’s of “sticks” in stock.
Then there’s $5 a gallon diesel to:
1.Run the harvester
2.Run the skidder
3.Run the truck to the mill
4.Fuel to run the drier
5.Run the truck/train to the distribution
6. Run the truck the BIG BOX store
7. Run the loaders, fork lifts etc
Pay the wages/benefits for all the people actually working in 1-7.
So lumber is NOT a going down in price for awhile other than a large drop in demand. Even if the stop (cancelled) half of the planned new builds the demand will still be high.
Don’t forget the original owner of the trees and land.
duneslider
Riverton, Utah
It has come down a little bit, that $6.98 is a good drop from less than a month ago. I think it could drop a little more but given the current world circumstances I suspect we won't see below $5 for a long time (maybe never). Hopefully, I am wrong!
tjansson
Northern Vermont
Prices have definitely drifted down a bit in the past month. I'm watching 2x4x8, 2x6x8, and zip sheathing, as I'll need some in the next 6 weeks. My question is, when do I pull the trigger? Once I see the price go up again?
Within a 2 hours drive I have non-insignificant difference in price at the box stores, but it gets complicated with gas price, ferry tickets, state sales tax or lack there off, value of my time...
MushCreek
Upstate South Carolina
I just ordered some 1/4" marine plywood for $60 a sheet, and feel like I stole it. I don't need it right away, but the supplier said that the price has been changing (up) with every delivery they get. Really small local sawmills are selling rough-sawn hardwoods for less than you can buy garbage lumber at the big box stores. I just got some nice white oak for $1 a board foot.
tjansson
Northern Vermont
Local rough cut, green hemlock or pine is an cheaper option for me too, but for my construction I need dry, nominal sized lumber. At $5 per actual 2x4x8 it's a good value. Might be using some for concrete forms.
Sumboodie
AK
1.Run the harvester
2.Run the skidder
Harvester would usually work with a forwarder.
Feller buncher with a skidder.
Some outfits use a harvester on the landing to delimb and CTL.
sleek98
Kansas City, MO
Depends on how much stock they have from Dec through Feb still on the shelves. I work for a lumber company and we stacked our stores to the rafters this winter worried we might not be able to get product in the spring. Our lumber is high priced and until we blow through it all I don't see them lowering it.
I am needing to build our lake house so I am hoping the futures stay low and the prices drop this fall when we go to frame.
MushCreek
Just got home from Big Blue, and prices are kind of all over the map. I need some 10' 2X8's, and they went from $18 a few weeks ago to $12 now. But a 16' 2X6 is $30! Oddly enough, a 16' 2X8 is only $22, much cheaper than the 2X6. 2X4's are still $8 for the cheapest ones. Sheet goods are still way out of line.
johnharris
TN
The owner of a local lumber yard said prices temporarily dropped early last fall cause people held off buying lumber at that ripoff rate. The big box stores shelves where overstocked so they had to get it cleared.
