Dehydrator PCB board parts
v1ru5879
My parents dehydrator went out on them and I took it apart to see if there were any quick fixes. Thermal fuse was good so I checked out the control board and found this guy was burnt out. Any way to get another one of these? It looks like a resistor but I do not think thanks what it is
V
v1ru5879
I cut the legs off and scraped off the ceramic coating stuff. Now where would I be able to get a fuse like this?
V
v1ru5879
This was the best pic I could get of it, damn thing is tiny
V
v1ru5879
It is stamped into the metal, gonna have to find a magnifier to take a better look
BillK
Beautiful Southern Maryland
First thing I would do is out an ohmeter across the two spots where the fuse is connected. Probably going to see a dead short by the looks of the fuse. Then you need to figure out what made it blow. Replacing the fuse is probably a waste of time without finding the actual problem.
You should be able to find a 12 amp 250 volt fuse at Home Depot but you will have to solder the leads to it.
wyliesdiesels
Modesto, CA
The fuse essentially prevented a fire from igniting inside the appliance. A dead short would probably not trip the breaker as there is too much resistance with the small cord and other components...
walta
Dutzow Missouri
Soldering wires to a fuse is not an easy feat to pull off. You should look for a pigtail fuse that comes with the wires welded to the fuse.
https://www.ebay.com/itm/1521465731...4FMWIMMfehdXcuwFvGi3aoqmCT6VUujxoCnxMQAvD_BwE
I agree the blown fuse maybe the symptom of the problem and not the root cause. But I see that the board is discolored seems like there may have been a bad connection where it is discolored the heat from the bad connection may well have damaged the fuse and replacing the fuse may well fix the problem.
Walta
V
v1ru5879
I got a 10 pack on amazon that will be here tomorrow with the legs on it already. On the underneath one of the legs looked like a cold joint so I will try the replacement and see if it does anything. Worse case I am out 8 bucks. As far as getting a new board, how would I go about finding one? Just an ebay search maybe?
Jim greengo
Behind my house
Or post the model number off of the machine and maybe the number off of the board.
I can check at my favorite place for appliance parts and see if they show a board for it next time I'm over there.
V
v1ru5879
Here are pictures of the board, you can see where the bottom looked like a cold joint, maybe a result of it blowing?
walta
Dutzow Missouri
Please post a link to the fuses you ordered.
I look on Amazon but failed to find any I thought was a match.
Walta
pizza
Midwest, USA
First thing I would do is out an ohmeter across the two spots where the fuse is connected. Probably going to see a dead short...
yes, try that first. if it's not a short...
then if you don't have the ability to actually troubleshoot the circuit and do component level repair beyond this fuse, then short the fuse out and see if the board works again. if it doesn't work, then don't waste your money buying new fuses. find a new board.
V
v1ru5879
Well the fuses got here today and like I thought they are definitely bigger, same specs however.
V
v1ru5879
Finally got around to putting this fuse in. Used soome solder wick to get the remnants of the old legs out and got this one put in as close down as possible. So far everything seems to be working fine. I ran it as hot as it would go (160f), and let it run for 15 mins. I am guessing the fuse was the fix. Gonna run it some more and see what happens, fingers crossed that this was a quick fix!
slimpickins
Canada
You may have had a voltage spike!
I'm late to the party here, but that blue component next to the fuse appears to be a varistor (MOV "Metal Oxide Varistor") which is a surge protection device. (AKA a Voltage Dependent Resistor or VDR) They work by reducing their resistance dramatically when a power spike happens. They are installed across the power lines, and normally have a very high resistance. If you had a spike, the varistor essentially shorts out the spike, and if it is a big enough surge, it will cause the fuse to blow. That's how they protect the circuit. Their response time is in micro- to milli-seconds.
In any case, the varistor may look fine but may be damaged internally and have a lower resistance, and current flowing through it. Voltage spikes will eventually kill them - the bigger the spikes the shorter they last.
If you still have access to the board, I recommend checking the resistance across the varistor. It should read as "open" or very high resistance, Mega-ohms or higher under normal conditions. The varistor should also feel cold or cool to the touch. If it is warm, that means it is carrying current and is likely damaged.
They are inexpensive to replace.
