Above 1200 Sq/FT The Empty Cup 40x64 Post Frame
E
eastmtn
Western Washington
That's crazy what one pothole can do. Hoping for the best as they sort through your claim!
Thanks. Unfortunately The City denied the claim today stating that the storm drain depression wasn't deep enough or far enough into the street to cause that kind of damage. I respectfully went on record as disagreeing with their decision and opened a claim with my insurance. Hopefully my insurance can continue the matter on my behalf. To be continued. Perhaps I should have started this process with my insurance first. To be continued.
jollygreengiant
Ontario, Canada
Thanks for all the info eastmtn! I'll have to go through the links you posted and check them out. Definitely going to check out the discada cooking.
E
eastmtn
Western Washington
Here are some pics of the ductless hybrid install. 1K ducted furnace for the enclosed shop. This unit is heat only and has the typical replaceable filter seen in ducted air handlers.
2K wall units for air and heat in the large open area. The one up in the loft was put in a spot I had slotted for my desk, server cabinet, and surveillance TV. I'll have to change the layout To avoid having a noisy blower close to my head when I sit at the desk.
This is where the outdoor heat pump will go on the west side of the garage. 5 ton unit.
The HVAC company also ran the ducting for the bathroom light fan.
E
eastmtn
Western Washington
I got a chance to have some fun and run some low voltage wiring like Ethernet, speaker wire, and Fiber optic HDMI's. Finding a path to keep electrical interference away from the wiring proved a challenge, especially when it came to getting around the posts. Some of them were butted up to the exterior panels so I had to take interesting paths with the blue flex tube to make it work. So far I have laid down over 300ft of flex tubing, 250 feet of speaker wire, 200ft of Ethernet, and 25M (82ft)of HDMI. I'm probably halfway done at this point.
In this pic I'm letting the fiber optic relax before I insert it. The bends in this type of cable are more prone to permanent damage from aggressive bend radii so I have to be careful. That corner post had no room behind it so the electrical had to go up over and through the rafter to get to the other side.
Having a legend and both ends of the cables marked helped greatly to keep everything sorted. Once all the cables are terminated I'll make up some more descriptive labels and a couple of small access panels for the ENT flex tube that take off in multiple directions from a common point.
E
eastmtn
Western Washington
The foreman and I tested the fiber optic HDMI's with an old Xbox, a 4K movie and a portable 4K monitor. The upstairs run is 29ft and the downstairs run is almost 50ft. 4k picture signals start to degrade after 10ft with copper cables. I ran 8K fiber optic for future upgradeability.
I happened upon a great deal on new commercial 2K security cameras being sold by the case. They are smart cameras with night vision distance of 160ft, face detection, and a few other perks that go for $400 a piece. I paid $60 per camera. That's a savings of $3,400. I don't have use for 20 cameras so I split the cost with a coworker.
E
eastmtn
Western Washington
Another plumber has flaked on the job. We have a third one coming out next week to look at the job. The GC has been trying to line one up since January. We've managed to stay busy and work around the plumbing up to this point.
The GC is also having a very difficult time locating mineral wool insulation. He says part of that is the lack of knowledge by local suppliers on the product itself. Most go with fiberglass around here. The interior liner panels have been on the job site for at least a week.
The outdoor lights are installed. To avoid drilling the posts and staying within recommended height for motion sensing, the electrician's ran the wiring for one of the security flood lights externally. There are wall paks over each bay in case I have to wrench outside at night. One dusk to dawn barn light over the man door.
The building passed electrical inspection a while back. We're waiting on the local POCO to pull the cable from the transformer and install the meter.
Maxcustody
West Virginia
Love the look of the wall pak lights, same thing I am going to use over both 12 ' doors (y)
I have contacted my local power guys, they said they will come out and hook you up😉
jbrentd
Northeast Oklahoma
Nice deal on what sounds like a pretty good security camera. Do you already have an NVR/DVR system? I'd like to upgrade my system one day, as it's horrible at motion detection.
The new lights look great. Hopefully you and your GC can get those subs moving along. Might need to squeak a little more.
E
eastmtn
Western Washington
Thanks. I currently have the full Ring system and although it's good with motion I found it lacking in facial recognition and capturing plates. Being married to the cloud was not appealing either. My property is at the end of a long dirt street but because the road continues around the back of my house, people think that it's a through street and end up trying to turn around in my backyard. My property is also backed against a public trail system so we get the occasional wanderer.
And that's when I discovered the rabbit hole. I tested a few other options over the course of a year and this NVR system by Uniview is working very well. It's leaps and bounds over the consumer brands but does have a learning curve. All of the cameras are POE so one ethernet cable provides audio, video, and power. When the power and internet go down my UPS kicks in and recording continues uniterrupted until the back up generator can be started.
You're right. This wheel needs to squeak more to keep things on track with the build.
E
eastmtn
Western Washington
Would love to find that deal on 10 cameras.
This is the company's used and new closeout website offerings. They have great customer service and are geared more for dealers and licensed installers but will not hesitate to help out individual buyers.
This is their retail storefront.
Most of these camera's and equipment are NDAA compliant, meaning that they don't have federally banned Chinese manufacturing tech and can be installed on government premises.
Nellys also sells alarm control and entry products.
E
eastmtn
Western Washington
The build is back on at the Empty Cup. I finally got a plumber. The contractor trenched to the well yesterday and put sand down.
The first load of insulation also arrived. I'm using Rockwool. Sourcing 24" proved quite difficult but the contractor ended up finding a local supplier across the pond in Seattle which makes delivery convenient. I'm having R-39 put in the ceiling and R-23 in the walls.
Sill no power to the site yet. The Poco contractor came buy and looked at the job a couple of days ago but has not been back since.
Maxcustody
West Virginia
Great to hear, glad my guy finally showed up...............have to cut him some slack he did drive from West Virginia.:ROFLMAO: (y) :beer:
E
eastmtn
Western Washington
I'll definitely cut him some slack. I'm just happy that a plumber is going to show up...with tools. Hey Scott, you got a lead on a good West Virginia line serviceman to hook up my power?!! 🙄😜
I found out that the last crew wouldn't do the job because there was water in the transformer box. 🤨 Last time I checked, Western Washington has a propensity for rainfall that's why the serviceman carry sump pumps in their truck. Dry vaults and hand holes don't exist up here in May. 🤷
Man doors were delivered. And also the crew had time to start on the insulation after prepping the water trench.
Believe it or not that yellow contraption is a push broom with dust pan built in made by Karcher. It makes quick work of cleaning large areas. No motor. The bristles are geared to the wheels to rotate as you push. Best of all, my son thinks it's fun to use. Win win.
Maxcustody
West Virginia
It is coming along. Glad you are finally making some progress. Hopefully the electrical gets sorted out soon. Ridiculous on the issues with water in the box.
E
eastmtn
Western Washington
I'm happy to report that the plumbing has been roughed in and connected to the well. Here's a before an after pic of the well head and intercept. There's a valve here and at the new garage.
BD4D1481-3DD1-4977-89A1-EEC1F4330F74.jpegCD4C8CEC-70EE-423F-97C2-0F3F13F1AB5A.jpegDC052B83-9CFF-481B-B0D9-A56DEBE8BD76.jpeg
Here are a few pics of the water heater, utility sink, pressure washer, and toilet room stub outs. I think that a studor vent will be installed in the sewer vent to avoid taking pipe through the roof and having to flash around the penetration. The wiring next to the toilet is for a bidet/toilet combo with a heated seat. I figured, if the wife kicks me and the dog out at least I'll have a few comforts.
7D712918-700B-433B-89A8-4A972D1A1D84.jpegAF1A7AA7-0844-4579-9257-FEF584453B51.jpeg7091EE24-B5BD-49DC-88CE-E84C76623C63.jpeg
E
eastmtn
Western Washington
Great to hear👍 Congratulations!
Thanks Scott!
A buddy of mine made this plaque for the garage. He's recently taken up woodworking, by burning designs and using resin and lacquering techniques. This one is Leopardwood. It's going to be a good conversation piece because of the amount of symbolism within. It was a pleasant surprise to get this in the mail along with some Scandinavian yeast for brewing. My wife brews beer so she's looking forward to trying the new yeast.
Maxcustody
West Virginia
Thanks Scott!
Very cool! Even better your wife brews beer............... :beer: (y)
83VillageRepair
Merkel, Texas
"If you want to try your hand at cooking underground then Imus and Umus are the way to go. An Imu is a Hawaiian style of earth cooking and an Umu is nearly the same thing from Samoa. Think Kahlua Pork. For these types, moisture and moisture retention is really key. That's why they use banana leaves as insulation."
I spent three years on Tutuila working for American Samoa Power Authority. Spent many early mornings working the umu with my Samoan Uso's. Really nice build! I am getting some good ideas.20150628_085457.jpg
E
eastmtn
Western Washington
Talofa uso, faafetai. I've only seen Tutuila in pictures. I've gotten as close as this geothermal power plant in New Zealand but have never been to American Samoa. It seems that we might have a few things in common.
The va'a I race in the Sound here in Washington is a Huki designed by a Hawaiian who builds the only handcrafted surfskis and outrigger's in the states.
83VillageRepair
Merkel, Texas
We definitely have some things in common other than the power industry. I raced V6 and V1 PaoPao's (Va'a) the whole time I was there.
Here is my favorite pic halfway through a 20k paddle out to the "green buoy" I am the little Palagi in the orange shirt in the front V6. We used mostly Tahitian boats and paddles. I have always wanted to try a surf ski. Did you ever run into Harry "Spike" Spicher the US lineman trainer in the south pacific?
E
eastmtn
Western Washington
Oh wow! The world can be a very small place. I've never paddled a Tahitian paopao. It looked like it took good balance to fly the ama. Unfortunately I've never heard of Spike before. I was in Wellington and Hamilton in 2014 with Transpower to control the North and South Island power grid.
From the photo you blend in pretty good and don't look like palagi. 😂
I've paddled surfski's for 8 years. It takes some getting used to. You try to power stroke while balancing on a beach ball and huli all day long until the light bulb comes on. Be direct and purposeful from the catch to the exit. Don't be in a hurry. To go fast you have to go slow. It's gotta be the same for paopao's.
Did you ever travel to Turtle and Shark near Vaitoga? The Samoan family that took me in is Letuli. Their ancestor is the chief that took in the woman and child in the legend. It's on my shortlist of places to visit.
83VillageRepair
Merkel, Texas
Why yes I have. One of my best friends on the island is from Vaitogi. The Turtle and Shark area is beautiful. I am going back at Christmas hopefully if lockdown is over and flights are more regular. Our son is still there.
I think the paddling technique is similar. I am actively looking for a v1, oc1, or a surfski. Kayaking is just not the same. I love V6 the best but nothing like that around here.
Sorry to blow up your thread :)
E
eastmtn
Western Washington
Drop in anytime. I sent you a PM.
zc15
SE Michigan
Very cool to see more paddlers on here!
Different discipline, but a lot of the guys I race against also train in surfskis with doubleblades
E
eastmtn
Western Washington
Ah yes. I remember seeing your canoe on your 24x30 thread and thinking how much technology has changed. Those are some tough and fast boats. I've seen similar marathon canoe races in South Africa. I have a lot of respect for that type of racing.
ned911
Austin, TX
If I would have known 30 years ago that my power company (HL&P, TEP) would have led me to the South Pacific I might have staid (my wife is Hawaiian). But I was in the regulatory side and as the industry went through deregulation it didn't seem safe :)
E
eastmtn
Western Washington
Yesterday the apron was filled in and leveled to match the rest of the motor court. When the site was being prepped the excavator built up the pad an additional 18 inches to get higher above the water table. They also put in a 4ft deep curtain drain and drain rock bed around the perimeter to keep the adjacent retention pond runoff from undermining the site. At some point after the build is done I will have the whole motor court refinished with concrete. Here's a before and after to highlight the material brought in to make an acceptable approach into the garage.
E
eastmtn
Western Washington
E
eastmtn
Western Washington
One wall is complete with the Rockwool R-23 and the other backwall has a good start. I originally planned for R-45 in the ceiling but due to cost overrun with furring out another 4 inches of the 2x6's in the ceiling and changing the already installed can lights I've decided to stop at R-30.
I chose mineral wool over fiberglass for it's higher r-value per square inch, less propensity to compress over time, fire resistance, and sound deadening. The building is completely wrapped with house wrap, insulation in the garage doors, and in the concrete.
Denwad
Chandler, AZ
I'm glad you explained why you went with rockwool! I was thinking while reading your last post "I wonder why he chose rockwool", and now i know!
killer thread! love it!
