Amazon Warehouse Deals
2manytools
Mt Pleasant, MI
Thanks @vwpieces. Picked up the Torin bottle air jack. Cosmetic damage was all done to the box. Definitely had a rough ride, but nothing leaking and everything is still factory bubble wrapped inside.
Hopefully just having it on hand will prevent any major breakdowns. You know how it goes 😉
Kbach
So you're the one!!! I've been waiting to find a deal on a AOH bottle jack and was excited when I saw it listed on here a bit ago. Click on the link and bummer....already sold. At least somebody on here got it! Hope it gives you years of good service @2manytools
Swervyjoe
SC
I've been waiting for one since I got a SWAG brake. I saw it but was trying not to spend even more money so it worked out for me.
vwpieces
Hills, PA
They pop up on occasion. Will msg ya if I see one under $70ish. Not too often they go under $80.
I put one on my 20T press and it was about the same price, same condition...
Put some oil down the hose for the piston. Mine needed some coaxing to pump but been great since for the few times I have needed it.
HotRodHudson
I bought the 20ton air bottle jack from HFT a couple years ago. It works great in my 4 post lift’s jack tray. Should have bought 2, I think they discontinued them.
vwpieces
Hills, PA
volvo problem
Got the Gearwrench 12 piece flex head wrench set a while back.https://www.amazon.com/gp/product/B0002U2ODE/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&th=1
Over half the swivel heads just flopped around back and forth. I like the set but cant have this. I searched for a fix but so far have not been able to find anything. Anybody know of a fix? If I cant make it work I'm going to send it back. Just wanted to give a heads up if it shows back up in this thread.
Cruzan80
Denver, CO
PugetDude
Superstition Mountains, AZ
I bought a Astro Rivnut tool with dies on AWD a couple of weeks ago. It arrived in the original box with all the dies, instructions, etc. The only mark on the box was the AWD "Thanks to you this product has a second life" sticker.
16 Gallon Ridgid shop vac coming this week- less than half price, advertised as "good" in the original box.
...and an 11# spool of .030 Mig Wire.
...and a 6" stainless steel dial caliper
vwpieces
Hills, PA
Cruzan80
Denver, CO
Just a heads up, the bearing puller has horrible reviews. The only good review is very generic, amd the rest are 1-2 stars.
vwpieces
Hills, PA
Just a heads up, the bearing puller has horrible reviews. The only good review is very generic, and the rest are 1-2 stars.
Deleted it, CTA hasn't been up to par even at 30% of retail.
Thanks.
I am usually just looking at numbers and it takes me bout a min to make a post after the collection is in the cart. Not really paying close attention to details.
PugetDude
Think those are for wood lathe.
Nope, these are carving chisels. Lathe chisels would be much longer and heavier. ( I have a wood lathe) Reviews are mixed; consensus is good quality steel with decent handles but poor factory grinding. I plan on sharpening them before use anyway.
If they are **** I can always send them back.
vwpieces
Hills, PA
Well, the 16 gallon Ridgid Shop Vac is on it's way back- the switch was broken. :(
Too bad, it was basically brand new.
Oh well.
I got a 30-60K BTU propane bullet heater heater the other day for $50. It is about $150 retail. It didn't work. Must have took a hit and fan blades bent, locking up motor. Deal was too good to send back so I took it apart and fixed it up. Works and its a keeper. Well worth the 30min I had in it.
vwpieces
Hills, PA
PugetDude
Oh well.
This one had an integral switch that was foot-operated. I could have replaced it with a simple toggle switch except this was the new "motor on the bottom" vac technology- top lifts off, motor says put. It would be too cumbersome to operate a toggle switch at floor level.
vwpieces
Hills, PA
More oddball SHTuff
bubinga
More oddball SHTuff
I'm confused 🤔
It's says vacuum,but the description says for air compressors.
Is the description just inaccurate?
dogdog
Grabbed this for a shop/house warming present for my brother. He always said he wanted a good vise, now he has one.
that is a pretty decent vise, I have the 5" or 6" ones from them as well... Bessey, the old craftsman one from sears also look the same "Almost the same."
