Big work push for Memorial day weekend-Water Lines.
930dreamer
Amarillo,TX and Stinnett,TX
I have an excavator reserved over the Memorial day weekend to run some more water lines to the shop and house. I'm guessing a poly type 1" line is the correct line to use, what do you recommend? I'm thinking the run will be less than 250'.
reader2580
Minneapolis, MN
Poly is what is used for the water line from my well to the pressure tank in my basement. I am pretty sure it has been in use for 40 plus years.
It seems pretty last minute to not have selected the type and size of pipe less than a week before the work is to be done. What if you couldn't get the pipe right now due to supply issues in your area?
dcg9381
Austin, TX
I ran 250' to the house. I used 2" PVC. Based on charts, minimal pressure drop. Check what type of lines you need for that length.
Daniel Dudley
You should bury that pipe in sand or else sleeve it. I bought 300 feet of 1" pipe, and put it in 4" drain pipe down below the frost line. I found 1" to be plenty and ran out at least 200 feet. We have a lot of clay and small rock here, so I was happy to sleeve it. Never thought of it again until this moment. Would have been happy putting the line in sand, It's one or the other.
I don't do this very often, or know a lot about it, but around here you sleeve it or put it in something soft. FWIW, I have dug up solid copper pipe that a rock had worn a hole right through, so it happens. It is a major pain to have to find and fix a leak or have to run a new pipe.
Hghgrad
Detroit MI
I ran 3/4” pex 200’ to my barn and it’s plenty sufficient for the farm duties. I’m sure the requirement for a house is substantially more.
930dreamer
It's 245' from the begin of my shut off to the outside water box to the house. 500' of Pex A 1" is $522.
MattN03
KY
I did the same to my shop for a wash sink and an outdoor faucet. It's worked fine and I have good water pressure. I hooked up my 2400 PSI pressure washer last night at the shop and ran it without an issue as well.
I did put the 3/4" PEX inside 1.5" conduit to protect it from rocks on our property (solid limestone shelf in places).
pcmeiners
930dreamer
I dug 240' today and placed the Pex into the ditch, just can't get the Pex clamp to clamp
930dreamer
How should I protect water line shutoffs? I'm at the tail end of installing a new water line to my vacation home ha ha. I'd need it accessible and freeze proof? Would this work?
mike93lx
Richmond, VA
That box will give you access and keep the valve clean. Not sure how cold it gets in your area though, and it may be just enough protection. It definitely isn't enough around me though. Irrigation lines and valves need to be blown out
930dreamer
I'm told 18" is the frost line and I'm digging to 36", this will be the main water line to the house. There's several other shutoff's but this will next to the house. We've seen -10 temps this last Winter..
mike93lx
Richmond, VA
But that cover is used at the surface, so the depth of the line doesn't matter.
If you get away with stuff at the surface, then this should be fine.
I'm used to shutoffs being way below the surface if they are left in service year round
mike93lx
Richmond, VA
No, teeing off this line with a ball valve to house and on the other end it's going to a hydrant.
If no riser, I don't think I would bother with a $50 irrigation control box. Their whole point is to give easy,clean access to a valve that needs it. Maybe I am missing something.
If it is 36" below grade, the enclosure won't matter for freeze protection
930dreamer
Box is more for finding the valve if need be!
930dreamer
I understand, trying to crimp Pex in the ditch doesn't work with a 12" bucket cut. Falling back and regrouping. Wonder what this pipe went to? Riser details if you can please. The Pex memory on this cut off is killing me. Meter box won't work for this application. Rental excavator trailer has a flat tire......
mike93lx
Richmond, VA
Haven't done a lot of looking, but septic risers are one option, although they cost hundreds.
For water service, a municipal agency would install a valve that can be operated with a long tool and the valve would be in a casing of maybe 8" diameter. A little hard to use a ball valve like that though.
Maybe a piece of 2-3' diameter plastic culvert?
930dreamer
I called the game, limped home with a slow leak on the trailer. I'm tired and my sweet wife smoked three racks of ribs, poppers are in the oven, potatoe salad and cream corn awaits all 12 of us for dinner.
A huge part on the water run is finished, just need to finish the line to the house and the hydrant at the end of that line. Will have to be sorted by October.
Renegade1LI
long island ny
We usually use 12" drainage pipe, cut out over pipe & place a cover on top like the one in the link.
