Vise stand from a 3"x24" screw jack
royce
fairbanks ak
This jack is as big as I've seen, 3" diameter screw.
I like the soft curves of the jack and harrow disc.
The concept is to tilt and roll, to move it, if I can get the geometry and center of gravity right.
R
royce
fairbanks ak
Royce
This looks like a great project. Please post lots of pictures and the explanation that goes with them
Thanks Don
The idea for this one has been stewing for a couple years and now I just stumbled into the right materials. I'm not to good at explaining, I'll try! Thanks Don
R
royce
fairbanks ak
Made a tire for the edge of the disc out of 5/8" round bar, to soften it up and ease the blows to the feet and ankles.
Also got the base welded to the disc, the jack body bolted to the base and it looks like the balance is about right.
The look reminds me of a mushroom for some reason.
R
royce
fairbanks ak
Cut the top of the nut off, to make a jam nut out of it.
Alarm bell to serve as part of the hand wheel for the jam nut.
R
royce
fairbanks ak
I was scoping out a buddy's bone pile today and came up with a 2" flanged shaft that fits a couple bearings I have in my pile. This is a good start to a horizontal swivel.
This set up will include a 4" Reed coach maker vise that is currently on an all position stand that works, but not well.
Roller bearings and a counterweight should help with making the design better.
R
royce
fairbanks ak
A little headway on the hub and axle today.
Made a brake shoe that will be driven by a screw and nut from a bridge clamp.
Opposite of that, will be positive stops at 90-45-0-45-90
R
royce
fairbanks ak
Made a couple hand wheels out of some ring gaskets and then our well standpipe went gunnysack.
Seems like this **** always happens on the weekend.
Managed to get some pipe today and moved a hoist over, to yard up on it.
Fingers crossed that I don't drop the SOB
R
royce
fairbanks ak
Thanks Kevin,
Bev will run the winch and I'll tend the hook.
It aught to be a comedy!
I kind of like the style of the hand wheels, too
R
royce
fairbanks ak
Just sit down for lunch after successfully getting the pump pulled.
The rigging is kind of hillbilly, but worked.
The first joint coming out of the pump was rotted in two.
R
royce
fairbanks ak
I was worried the positive rotation lock had too much shear on it, so opted to augment it with a spring plunger. Index holes 15 degrees apart, at a 3-3/8" radius
LXCam
That’s a hefty looking spring plunger. Nice work Royce.
Where'd you find that at Royce?. I used this style on a recent piece of equipment I developed and it works perfect for this application but I'm always looking for other styles that may be a better fit. This one is a 1/2" plunger with a 90 degree turn locking handle
Disregard that attachment pic, I can't seem to figure out how to make it go bye-bye
R
royce
fairbanks ak
Cam, it was made by Kipp and is coming from Grainger.
If you want to spend $150.00 on one, CarrLane has some really nice stuff.
Now then, what is the piece equipment you designed? and can you show more pics?
Thanks
LXCam
Thanks
Thanks. I don't remember what I paid for these but they weren't cheap either as I got them from McMaster.
I'll share, but hate garbaging up your thread with my nonsense :D.
Three years ago I had a project where we needed to replace 2200 slider lock assemblies for a jail. I watched our field crew manhandling all these doors that weigh anywhere from 300 to 500lbs and decided to come up with something to make everyone's life a bit easier. So long story short what you see here is V3 (V3 allows for pivoting a swing door so you can egress it thru its own opening whereas the previous versions just laid them back flat). This allows one man to grab a door (self-center acme screw clamp actuated assembly) whether it be a slider or swing and do anything and everything possible with no real effort. These things reduced my labor burden down to a quarter on the dollar and increased my safety margin by 95%.
Sorry about the crappy pic deal. I had to grab some stills off a video.
f74267a4-fb6e-48ef-b4be-28b58e2c26f0-jpeg.1680368
C3557006-30EB-44A4-8921-5263BEC88ED4.jpeg493479EA-8BE1-47B9-86D3-12039D7B21C0.jpegFB9D494A-E6F3-40C2-B58D-A7FF1E353094.jpeg
R
royce
fairbanks ak
Be right back with some pics.
Labor saving devices are some of the most satisfying to build.
Looks like clean work cam, well done.
Anxious to see more pics.
LXCam
Thanks Royce, much appreciated. I’ve got tons of detail pictures but only realized no stills of the final projects, just video.
LXCam
Super duper Cam
Wish we could pm pictures. I bet you’d really like how I did the self centering clamp system. It’s kinda cool. Unfortunately I won’t share those pics publicly or even with my own company. I built it so the system is serviceable but unless you know how it goes together you’d have to destroy it to figure it out. Lol.
R
royce
fairbanks ak
Rooted through the pile and chose a cast iron ball for the counterweight and welded the hub to the 3" screw.
This functions nicely, but is rough around the edges, and suits me fine.
Makes me think of Rube Goldberg!
KMScott
Came out nice Royce. I know you will get plenty of use out of it. I remember what all position stand it replaced.
I wanted to thank you for this cool stand you made for me a couple years ago. Today I finished this 8” railroad vise and put it to work.
R
royce
fairbanks ak
Thanks Kevin
My pleasure to work on any project of yours.
I really like the soft lines of the vise and stand, with the black paint.
It looks like it grew out of the floor.
