Oiling a GE motor ?
Thesian
Hi gents!
Doing a little cleanup on a new to me Toolkraft drill press. Removed the GE motor to inspect the electrical connections and noticed a label shown below. Oil with SAE10…ok.
Anyone that can point me to a good reference for lubrication points on this guy ?
Thanks !
Old hand
Hi gents!
Thanks !
There should be a plug in each end that you remove. Just a drop or two in each end. Over oiling has ruined a lot of electric motors.
T
Thesian
10-4. I’ll look for some access ports. A drop or 2 it is!
T
Thesian
Think I found them. These little holes lead to the bearing. Oddly, no caps…maybe PO removed :( I’ll figure out something. Thanks for the info @Old hand !
Old hand
That's the oiling holes . They should have a little plastic plug . Don't know where you could get them. Good luck!
The Cobbler
you can make new plugs from almost anything. They just to keep the dirt out . put on your thinking cap & get inventive
i idea, pc of rubber tube & a screw or rivet to expand it slightly
Jswain
Calgary, AB
If it's big enough you may be able to use the end of one of these
T
Thesian
I shouldn't say there were no plugs...there were, but they were made of saw dust :oops:
Yep....I'll likely tap it and make little threaded plugs. Thanks gent!
SRU1436
Bay Area, CA
These work great, I use them for all kinds of stuff. Use can also get them on Amazon.
T
Thesian
Thanks Sru...never seen those before and I do a fair amount of masking holes too. Plus...made in USA! I'll give them a shot.
