jserr68594
- Joined
- Dec 21, 2013
- Messages
- 120
The door looks like it's the wrong size for that opening if its fully closed, can't tell by pic if it's partially open. The seal should rest on the upper flat portion of the door not along the false raised panels.I'm very surprised anyone uses those terrible door "seals" anymore. The brush kind is much, much, much better for sealing.
Bigger hat brim should take care of it.I am quite certain that is due to heat.
If you look at factory made facia cover, it has "ribs" rolled into it.
With a flat brake bend on the edge, you will see this.
It is doing it's job, I'd suggest don't look up.![]()
