SRU1436
Hello-
I am seeking suggestions on how to remove the step bit from my hex drill. It's a harbor freight step bit that I can remove from the drill. The removal collar slides forward as designed but the bit will not come out, it's stuck in there. The hex portion on the bit was not mangaled when I inserted in there, but after I used it to drill a hole it won't come out. I've tried to pull but no go. I've contemplated cutting off the bit to leave the shank and place that in the vise to pull really hard in hopes it comes out.
Has anyone else ran into a similar problem and if so what was your solution to remove it? is there something simple I am not seeing?
