trbomax
Re: Painting, Caulk, and Aquanet
What caulk are you useing?
I cauked all my osb as well as trim in the house with the cheapo white latex caulk from wally. It used to be $1/ tube,now its $1.20,but still a hell of a deal.Decent shrinkage,skins over in a couple hours.I bet Ive bought 50 tubes of that stuff.Used it to glaze the nail holes in trim and staples in the osb.
edit) I pump it in with the gun and squegge it off with a plastic autobody filler squeege.Keep a can of water and a wash cloth to keep the squeege clean.Scrape the joints down like you were doing drywall.
With Valspar you may be able to just use the primer and one coat of finish paint. Pigment content is the expensive part of paint that determines coverage and Valspar is good stuff with a lot of it.
That looks great!
How much paint did you use?
Bull- Was that just one coat of each?
The texture reminds me a little of stucco.
Thanks for the info. I am glad it worked out for you. I hate having things not work for people when it has always worked well for me. I have found good paint usually does the job and is worth the extra $$.
Looks good Bull. One good thing about using screws (until you caulk over them) is being able to take them and easily remove the sheet of OSB. I've used both screws and nails when hanging OSB. By far the fastest way is with the framing nailer, and for some reason, it gets more fasteners
Start saving your bucks too, you need one of these.
