WoodsTruck
- Joined
- Jan 12, 2013
- Messages
- 1,025
Looks great.
Are the lower rocker panels showing rock chips after that many miles?
Thank you.Top notch work as usual Mike! Really impressive as is anything you get your hands on. I believe you're right when you say it looks better than it did rolling off the assembly line.
Thanks. The tape just helps to keep the razor blade standing proud ever so slightly above the surrounding clear and just allows you to remove the bulk of the run. Once close switch over to around 1200-1500 grit wet sandpaper then some 2000-grit followed by compounding and you shouldn't ever see it.Wow! That looks fantastic. Cool trick with the razor blade, never would have thought to tape it up like that. Nice work!
Thanks Cam. I'm not necessarily regretting purchasing the Milwaukee cordless polisher but for the initial step I think I'll keep with the corded Buffmaster for the available torque. Plus it just feels right in my hand, like an old friend.Wow Mike, she’s gorgeous bud. As always another fine job. As for the battery deal you’d be amazed how much better the higher amperage batteries will make that unit perform. But the trade off is weight and balance which might kill the pleasure of working with it.
Looks great.
This is the picture I love! To the average viewer the weatherstrip wear marks proclaim to the world that this beauty is a well loved survivor, OEM paint and with tasteful upgrades! On your B&D buffer, have you had to replace the speed control/trigger switch? B&D made the Snap-On ET-1475 variable speed buffer for years and the switch became NA after B&D was bought out. I actually need to search eBay for a NOS switch for mine because it died when I went to use it on my boat last year! Although I might have a couple stashed in my pile that’s left over from my tool-in….
Beautiful truck!
You did an excellent job Mike! I tried to get several body shops touch up a door for me and they politely said no. They said it would not blend to their satisfaction. They made it sound like blending cannot be done any more. I guess I need to find a Z trained shop!Thanks guys.
Coming from a couple of paint experts, I'm flattered. Blending was never my strong suit.
Iv had two dewalt cordless paint correction tools in the past. While the battery lasts longer the added weight of the bigger battery kills your arms after a few hour stint of polishing. The dewalt I’m sure is different then the Red club but the same principle applies. One reason I aways go back to rupes is the balance of the machine. It balances the weight and pressure you are putting on the padsThat m12 polisher is on my long list of things to get. Mainly for roloc discs. Have also wanted to try it for headlight restoration. Since I know you have experience with the 3m kit, how do you think the m12 would do for headlights?
If you know anyone with a bigger battery I would try that. I have a bunch of m18 power hungry tools, chainsaw, hole hawg, mud mixer, 9" cut off saw, and the list goes on. My 5.0 batteries are noticeably less power and less run time then my 9.0 and 12.0s. Another thing I learned when doing that pinion nut is batteries get weaker over time. I had a 5.0 on my high torque impact and it wasnt doing anything. Put one of my newer 12.0 on and it crushed it no problem. Bigger batteries are very expensive so I'd hate to buy one and hope for better results but if you know someone that has a bigger battery and can borrow it for a day to see.
Personally, I don't think my son thinks much of it as it's all he knows, we just tear into things. He doesn't know the contrary so unfortunately he will probably never fully appreciate his upbringing.
I've mostly converted now to cordless tools just for convenience sake. I have noticed the things you mentioned - many lack the balance and trigger control as compared to their pneumatic counterparts. That said, weighing the pros and cons I still think cordless is more convenient (and much much quieter). In situations where you need control tho...may never be worth switchingMany know that I am not over the top on cordless tools and have a hard time justifying something that requires batteries, however, I got to thinking about the cord management that I've dealt with for all those years when polishing a vehicle. I generally throw the cord over my shoulder much similar to when I'm painting and throw the air hose over my shoulder to keep from coming in contact with the body of whatever I'm working on.
I will be giving these a full test over the weekend so I hope I am not disappointed.
I have the M12 polisher but seldom use it. But the M12 Right Angle Die grinder gets used almost everyday. It's the best of the M12 line in my opinion.
Incredible paint work, Mike.
I want to add a table lift to my hydraulic press, will you post a picture of the rest of the mechanism? I'm curious about what keeps the cable from free wheeling. I'm thinking about using a boat winch because there cheap and have a built in ratcheting mechanism.
I love trails like this.
Thanks for this. I was away too but happy to see this information today.Sorry for the late response Mike as I've been away for a bit.
Most of the time when we wash our vehicles we simply run a water sprite (synthetic chamois) over the inside of the door jambs and clean the paint as well as the gaskets but once or twice a year we will treat with some 303 Protectant on a rag and lightly wipe over the rubber gaskets. It keeps them soft and pliable for a long, long time.
Heck Mike, you were in my hometown and I didn’t even see the entourage! Been living in Thermopolis for several decades! Soaked in the stinky water many times, and the kids learned to ride dirt bikes at Gebo! Nice to see very familiar pics. Hope we treated you well!
Mike,
Great photos of some awesome scenery. I can understand your love of this area and the desire to return.
Good on you to help out the couple having mechanical issues. Hopefully, they showed you some appreciation. I try to stop and help people when I know it's within my capability. I'm not looking to be rewarded, but do it because it's the right thing to do and it gives me a good feeling I helped someone out. It is annoying when you get no thanks or acknowledgement that you help them. Last time I stopped, it was for a woman who had a flat. It was obvious that she did not know what she was doing and was improperly equipt to change the flat. I stopped and was able to use my jack (4,000lbs old Craftsman scissor jack) and tools to get her on the way. The most aggravating thing about helping her was she couldn't get herself off her phone the entire time I was helping her. In addition, she didn't even care enough to offer me thanks or compensation (buy you a beer) or anything. Not that I was looking for any compensation, but a little appreciation would have been nice....
Sadly, he probably didn't understand your explanation why you wouldn't want to use something it was not designed for.....To be honest Mark, I had to give him a tow, he was blocking the trail.
I think they appreciated it but I could tell the guy was frustrated, as I would be too. I think he was shocked when I jumped out, reached under my rear seat and grabbed the clevis hook and tow strap. Although he was pulling his winch cable out to hook to me when I was negotiating the trail to get in front of him, I explained to him that he didn't want to use his winch in that manner as it is hard on the brake/clutch setup in the winch. I explained they are designed to pull from the drum and not to be yanked on from a tow vehicle. I hope he appreciated my unwillingness to damage his winch but he really didn't say much.
Mike thanks for posting more photos from another of your trips. Awesome looking scenery and some big open country! I really enjoy your trip photos.
Jay
I definitely enjoy your vacation photos. The landscapes you show are so different to anything we have here in Britain that it's always interesting.Thanks Jay. I'm not sure how many people want to see vacation photos compared to shop or project photos so I appreciate the comments.
