Crowbarman55
- Joined
- May 22, 2021
- Messages
- 1,101
Is it safe to run a bare copper ground through metal conduit for a 240volt hookup about 15 feet from a sub panel to a AC disconnect?
No. Just the 3 wire's and no junction boxes. There are 4 elbows to get around a wall.Is there anything else in the pipe,any junction boxes?
With 4 elbows, I can pretty much guarantee that the conduit is NOT one piece.If the conduit is continuous, you can just use that as the EGC.
Thankfully I didn't say it needed to be one piece, just continuous. Meaning no switches to pvc, liquidtite, etc, or gaps.With 4 elbows, I can pretty much guarantee that the conduit is NOT one piece.
With that many joints, is it still safe to use the conduit as EGC?
Ah, so it's already installed.
Since the conduit can be the EGC, I would expect the wire could be bare, but stuff like that can be location dependent...where are you?
I only use bare wire for connections to ground rods and water pipes , but I am no electrician.In Michigan. The wire is installed. Nothing has ever been hooked up yet. This is for a new install 18K mini split. Because I have not gotten a yes or no answer, I will probably just pull it and replace it with covered wire.
Why, there is nothing wrong with a bare ground wire in conduit, just harder to pull but you have already done thatIn Michigan. The wire is installed. Nothing has ever been hooked up yet. This is for a new install 18K mini split. Because I have not gotten a yes or no answer, I will probably just pull it and replace it with covered wire.
Depends on the OP's thoughts when he asked if it was "safe". "Safe" as in perfectly functional and serving the same purpose as a green insulated wire. Or, "safe" in the eyes of an electrical inspector who may or may not come up with some assinine reason that it doesn't meet code in his jurisdiction.Why do you think a bare copper wire is any different than the bare metal inside of the conduit?
Safe as in will it negatively affect the operation of the unit or cause electrical shock somehow. I'm not concerned about the inspector at this time because I call him Mr. Magoo.Depends on the OP's thoughts when he asked if it was "safe". "Safe" as in perfectly functional and serving the same purpose as a green insulated wire. Or, "safe" in the eyes of an electrical inspector who may or may not come up with some assinine reason that it doesn't meet code in his jurisdiction.
I'm quite certain that it is, and I would probably not hesitate (much) to do it myself, but my concern is the possible "loss of mechanical integrity" due to a loose/missing/corroded fastener on one of the (many) joints.Conduit is used as EGC all the time
yesI am having a ground wire in it either way. I just wanted to know if it being bare will be a problem. Code aside, is it okay to use a bare wire in conduit for a ground?
Todd
