Bare copper ground wire in metal conduit
Crowbarman55
Is it safe to run a bare copper ground through metal conduit for a 240volt hookup about 15 feet from a sub panel to a AC disconnect?
C
Crowbarman55
But is it safe to use the bare ground wire in the metal conduit? I can pull it out and replace it with green covered wire but, if I don't need to.
mike93lx
Richmond, VA
Ah, so it's already installed.
Since the conduit can be the EGC, I would expect the wire could be bare, but stuff like that can be location dependent...where are you?
C
Crowbarman55
In Michigan. The wire is installed. Nothing has ever been hooked up yet. This is for a new install 18K mini split. Because I have not gotten a yes or no answer, I will probably just pull it and replace it with covered wire.
mike93lx
Richmond, VA
I only use bare wire for connections to ground rods and water pipes , but I am no electrician.
Why replace it at all? Just use the conduit
Firebrick43
West central Indiana
Why, there is nothing wrong with a bare ground wire in conduit, just harder to pull but you have already done that
tdkkart
Eastern Iowa
Why do you think a bare copper wire is any different than the bare metal inside of the conduit?
Depends on the OP's thoughts when he asked if it was "safe". "Safe" as in perfectly functional and serving the same purpose as a green insulated wire. Or, "safe" in the eyes of an electrical inspector who may or may not come up with some assinine reason that it doesn't meet code in his jurisdiction.
C
Crowbarman55
Safe as in will it negatively affect the operation of the unit or cause electrical shock somehow. I'm not concerned about the inspector at this time because I call him Mr. Magoo.
Thanks
Steve W.
Southwest oHIo
Conduit is used as EGC all the time
I'm quite certain that it is, and I would probably not hesitate (much) to do it myself, but my concern is the possible "loss of mechanical integrity" due to a loose/missing/corroded fastener on one of the (many) joints.
Personally, I would keep the ground wire. Whether it's insulated or not doesn't really matter.
C
Crowbarman55
I am having a ground wire in it either way. I just wanted to know if it being bare will be a problem. Code aside, is it okay to use a bare wire in conduit for a ground?
Todd
billconner
Thousand Islands NYS
I worked on maybe 150 projects over 40 years, a lot designing lighting. I am not an electrical engineer but every project I worked on with an ee required a ground wire in the conduit. A couple design build projects where the electrical contractor made the call left them out.
