When I tore mine apart, the lifting arm had a threaded rod on each end as part of the whole unit.( main pivot point) that rod doesn't turn. It is part of the casting. I took the large nuts off the side, and slid it out. One side of the lifting support arms comes off (at the saddle end) which allows the jack to come apart. the other end of the lifting support arm was still riveted ( I guess thats what you would call it) and stayed with the jack side. Now the other jack side I couldn't seperate the lifting arm and support arm from the side, which made it alot more difficult to clean up. Major pinching finger moments. I can't see where a grease fitting in that hole in the lift arm goes to anyplace. I didn't notice any holes in the main pivot point rods. Maybe I over looked that. I just greased up the rods when I put them back together. It definately would have been easier if it had nuts to take off instead of those rivets. I will have to see if I can get a fitting in there and pump some grease and see where it goes. Thanks again for all the input you guys provided. much appreciated - Breeze
P.S. I have always known (zerks) as grease fittings - I will in the future try to refer to them as zerks
Hey, some people refer to it as the "cockpit" and others the "flight deck" as long as we all know what's being referenced that's all that matters. Try a little low pressure air to see where it's coming out perhaps. Also make sure it's been cleaned out well. Old grease can harden and plug up the passage way.
I think we've
for a while now don't you? Thomas
All compete with good sheet metal...........
