Pole barns and attic trusses
tstaude
SE Wisconsin
I have an interesting build going right now, you can see my thread below....I have to get some more pictures up.
I ended up with a mezzanine area on top, which you could easily replace with some attic trusses.
Because of the situation of a free barn I stuck with the rafters.
Good luck!
billconner
Thousand Islands NYS
Good luck!
That's very close to my project under construction, except sticker frame walls instead of posts and headers. Very nice!
F
FredWurlitzer
Western NY
So I’ve made a final decision on my overall dimension.. 32x36X14. I really wanted to stretch it to 40’ long to get the most out of the lumber, but I just don’t have the space to swing it (obstacles such as a deck, 500 gal propane tank, adjacent 10x16 shed, etc..)
I’m also deciding on scissor trusses with a partial mezzanine. I would like to do 7/12 top chord and 3.5/12 bottom chord. The trusses (6 total.. 2 standard structural end trusses and 4 scissor) will sit directly on a 3-ply column with 7’2” spacing.
One side wall location is already determined via string line. Just need to finish running string line and layout for the other 3 walls. Then mark hole locations and get to augering.. hopefully here within the next week or two.
