Car mat cleaning life hack
dwasifar
Advertisements for all weather car mats always show some smiling customer rinsing the mat with a hose: "Easy to clean!" I don't know if that's true in other areas, but here in the slush and road salt Midwest, you can scrub one of those mats until your fingers bleed, and when it dries, it's still brown and gray with ground-in dirt.
So today I had an idea. Here's a three year old set of mats after a trip through the dishwasher:
All the ground-in dirt is gone. They don't look like new, but they look a whole lot better than they ever did cleaning them by hand.
Today's life hack.
Wiz02
Southeastern PA
Today's life hack.
Great idea, @dwasifar . Now I'm not trying to proposition you, but you must be single or divorced. I can't imagine what would happen to me if SWBO found out that floor mats were in the dishwasher, but it would not be pretty. 🤕
Firebrick43
West central Indiana
Its not our fault that you chose poorly of whom you married. My wife doesn't care as long as it doesn't smell like diesel when I am done.
D
dwasifar
Actually my wife saw me putting them in the dishwasher, and her comment was, "that's a clever idea!" And not sarcastically, either. :D I got a good one.
D
dwasifar
Y’all must have either a commercial sized dishwasher or tiny floor mats. I can’t fathom how I could get one mat in my dishwasher let alone two. Granted I’ve never tried so I could be mistaken.
Well, they don't have to lay flat. I just bent them into sort of an arch with the dirty side facing the jets. I imagine you could also take out the top rack, bend them 90 degrees and stand them on their sides in the bottom rack.
Jeff C
Durham, NC
Taking out the top rack seems possible. Now you’ve got me curious because my mats have the seemingly permanent brown stains.
PCustoms
VT
I vacuumed 5 months worth or gravel from mine today and hit them with the pressure washer.
No need to bring them inside.
Had weathertech for 20 years and did this a couple times per year. A squirt of protectant and good as new.
Gravel driveway and spend a lot of time in the woods. Stuff builds up....
yelchevelle
Hoover, AL
I have used auto carpet cleaner on stuff like that and it works pretty good. I rinse off, then spray with the foaming carpet cleaner, agitate with soft to medium brush and rinse off. Probably 3-5 minutes each.
Crowbarman55
Having cleaned thousand of mats in the rental car business over 26 years in Michigan, vinyl, rubber and leather cleaner sprayed on and wiped off will do the same thing.
Todd
D
dwasifar
You can see the barest trace of those remaining in the driver side mat where my heels rest; a larger one for gas/brake, and a smaller barely visible one for clutch.
yatg
Southern Oregon
depends if the top rack has a spray bar, and if it closes off the flow when the rack is removed.
that funny noise you hear is a water jet hitting the dishwasher door.
jbfsr
Hampstead, Md
Knew a guy that put the furniture from a rack grade M1 Garand in his dishwasher. Claimed it brought out a lot of the "dents" in the wood.
58Yeoman
Central IL
My 2800 psi power washer works great on rubber floor mats AND the carpet mats, too. We don't have a dishwasher, but if we did, I wouldn't be putting any auto related parts in it for cleaning. That's just me, though.
thebmrust
Pressure washer is cold water, dishwasher is very hot water.
Also… preheat a turkey before thanksgiving in the dishwater. Can just put it on rinse (no detergent).
Yes, I’ve done it and got the idea from my grandfather.
Innovate1
Most overused word: Hack. Ok, it's a reasonable tip. But why does everyone call whatever idea they come up with a hack?
But it does remind me of an incident in Navy boot camp many years ago. Had kitchen duty running things though the dish washer. It was a conveyor setup. Mops were pretty grungy so I ran the mops through after we finished all the dishes. Worked great but I got yelled at. Of course you got yelled at for everything in boot camp, at least back then. :)
captain14
Bet you would not have been caught if you had cleaned all the mop strings out of the filter at the bottom of the machine.
Showkey
"MEMBER EMERITUS"
Wausau WI
As a side note to cleaning and getting mats black again with a like new look without being slippery.
WeatherTech sells cleaning and renewal kit ( not cheap) but it WORKS !!!!
My mats were 5 years old…….swap to a new car……..used the kit. The kit will clean and renew 5 sets of mats or more.
Renegade1LI
long island ny
I was thinking of this thread today as we were walking through the blood and urine being hosed down into the gutter where some guy got whacked last night in nyc.
Zeke
What, you guys don't have an old DW behind the garage? Hell, I've got an oven, hot plate, electric frying pan and microwave out there. You need these things to clean, strip, warm or heat, etc. Guy I know has a DW hooked up to hot water and all in the garage. Finishes up for the day and puts his tools in there. All nice and clean in the morning. Other things have been in there too, like carburetors after a soak. Just don't use off-the-shelf DW detergent. A little Simple Green goes a long ways except on aluminum.
no704
When I used to be a line cook in HS I wore sperry top sizers. They would get caked in grease. Ran them thru the commercial dish washer often.
